What Should I Use To Center Tile??? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 12:15 PM   #1
What Should I Use to Center Tile???
Hi All, my name is John and I'm new to the forum. I have been doing a bathroom remodel and had a question I was hoping someone could answer.
I am at the point where I am laying the tile on the cement backerboard. I measured the wall where the plumbing is located and realized that the pipes for the fixtures (bath spout, valve, shower head) are not centered.
Not a problem but it raises a question for me as to what to use as the centerpoint of the wall. Should I tile using the fixtures as the "center" of the wall or should I use the true center without regard to the fixtures? Is this a matter of preference?
If I use the fixtures as the centerpoint, should I tile the back wall to match the pattern or should I use the true center for that wall regardless of what I do in the front?
Any advice would be greatly appreciated. Thanks!
jlee0324 is offline   Reply With Quote
Old 04-22-2012, 08:40 PM   #2
I dont see how it makes a difference. If you are just using smaller tiles like 3x6 subways or 4x4 you probably wont even ever notice. However if you are trying to do some really cool pattern you might notice if you dont use them as the center point. How off are they? I think the rule for if something looks out of wack is if it's more than a 1/4 inch.
DIYGuy2012 is offline   Reply With Quote
Ceramic tiling Naz1298 Flooring 6 10-25-2011 07:20 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 03:06 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Tile shower with out center drain? jrdamien Plumbing 4 04-17-2009 07:43 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
