What To Put Above Shower Enclosure - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-21-2010, 12:36 PM   #1
Knows everything but that
Rewards Points: 150
What to put above shower enclosure
So ive been reading through a fair amount of threads about this and am getting a lot of conflicting and confusing information. I just installed a Sterling tub and shower surround and am drywalling the remaining portion above the surround. Do I need to put anything behind the drywall? One thread mentioned putting roofing felt behind it in case any water got through the drywall. Some folks stated to put the drywall to the tip of the flange lip and filled in the large gap (2") with hot mud. Others covered over it completely and caulked the small gap to the surround. What is the best way to do this? I know the wall will have a decent amout of condensation on it and occasionally get splashed from the shower. Will regular drywall, some primer and paint be enough to keep the moisture from the walls? Thanks!
Shane
JakAHearts is offline   Reply With Quote
Old 08-21-2010, 04:27 PM   #2
Rewards Points: 150
Here is a pic! Thanks again!
Shane
Old 08-21-2010, 05:28 PM   #3
I would not use drywall
I'd use cement board & tile it
Old 08-21-2010, 06:12 PM   #4
Rewards Points: 150
Oh yea, the wife wants it painted, not tiled. That should clear that right up.
Shane
Old 08-23-2010, 01:42 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Not an expert, but at the very least I would use moisture/mold resistant drywall and a name brand primer and bathroom paint.
Old 08-23-2010, 10:17 PM   #6
Rewards Points: 282
If it were mine, I would drywall and use a good oil base primer and paint designed for bathrooms and kitchens (either latex or alkyd). Silicone that inside corner where the drywall overlaps the surround flange. That should be good for a long time. You are not going to get that much water up there.
Jim F is offline   Reply With Quote
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 07:07 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Hardiebacker 500 in shower enclosure question (does board facing matter?) DyerWolf General DIY Discussions 3 01-20-2009 06:58 PM
Tiling a shower enclosure - questions re: hardiebacker & wall prep DyerWolf General DIY Discussions 10 01-15-2009 11:10 AM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 09:38 PM
