What Kind Of Tub Surround Should I Use? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 01:23 PM   #1
What kind of tub surround should I use?
Hey y'all. Recently, I decided to remodel the bathroom in my 1950's house. The room has never been touched, that I can tell. I demo'ed down to the studs and subfloor. I should mention that this is my 1st attempt at such a project. I also have a neighbor that has a good bit of remodeling experience.
The issue that I'm having is this. I used 1/2" green board( actually purple) all around the room. The original plan was to install Hardi-board over the green in the tub area. Tile was to be over that. Now I have just read(on this forum) that it's a bad idea to put Hardi on drywall, due to the wicking nature of Hardi. I also did not install any vapor barrier behind the green board.
It seems to me that I have a couple of options....
1. Pull out the green board in the shower. Replace with a vapor barrier and 1/2 " Hardi- board. Then tile over.
2. Leave the green board. Prime it and buy one of the molded surrounds that will not be water permeable.
I'd rather have a tile surround, but $ is definitely a consideration. I'm also very anxious about ripping out all the work i've already done.
Any opinions would be greatly appreciated.
Thanks,
Kevin
KB418 is offline   Reply With Quote
Old 06-21-2011, 06:03 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Leave it and cover it with Schluter's KERDI Mat. End of problem.
XXX
Old 06-24-2011, 04:02 PM   #3
Thanks, Bud. I looked into the Kerdi mat, and I'm worried that I may not have the experience to get it up correctly. There seem to be a lot of joints to deal with. Like I said, this is my 1st project. I think I'm going to bite the bullet and pull out the drywall, and replace with Hardi- board and redguard. I am planning to only replace the tiled portion ( just below the shower head). I don't want to go to the ceiling because I spent a lot of time kidding the wall/ceiling joint, and I really don't want to do it again.
That being said....
1- where should I make the cut in the drywall? I'm guessing it should be above the tile. How far above should I go, if at all?
2- is it correct to use thinset and fiberglass tape for the joint between Hardi and drywall? Can thinset be sanded and painted?
3- what kind of screws should I be using for Hardi board? Can I use the same 1 1/4" drywall screws or is there something special out there. Seems like I read something about stainless or galvanized screws. I've never seen them at HD or Lowes, but I haven't really looked.
Old 06-24-2011, 04:23 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would position the juncture below the tile termination, this way the finish doesn't have to be real pretty because tile will cover it.
The juncture can be taped and filled with thinset. Any thinset that is above the top of the tile can then be filled with joint compound and sanded smooth to fill the grainy thinset. Just be sure to use a paint that is intended for such locations. The tape is alkali-resistant tape, not regular drywall tape.
The screws are a specially coated screws with dual hi/lo threads and self-setting heads. They may be in the tile department. I find them with all the other screws where they are labelled (oddly enough) "Cement Board Screws". Go figure.
XXX
Old 06-24-2011, 04:41 PM   #5
How much is too much when it comes to tiles overlapping drywall?
Old 06-24-2011, 04:47 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Doesn't matter.
How about a couple of inches?
XXX
Old 06-24-2011, 05:11 PM   #7
I tend to over think things. Will the drywall not soak water through the grout?
Old 06-24-2011, 06:00 PM   #8
DIY staff
Rewards Points: 7,174
If you have the joint at or above the shower head it will never get wet enough to worry about damaging the green board.
If you use RedGuard also you are doubly safe.
Bud Cline (06-24-2011)
Old 06-29-2011, 05:30 AM   #9
Rewards Points: 77
can you use the kerdi mat and redguard? is that what you are saying mike?
mikeylikesit580 is offline   Reply With Quote
Old 06-29-2011, 05:33 AM   #10
DIY staff
One product or the other--not both---sorry for the confusion.--Mike---
Surround Sound Hookup Options Branden Home Theater 3 10-06-2010 02:40 PM
Tub Surround Install Question tmbrink Remodeling 5 02-13-2010 05:02 PM
What kind of caulk around tub surround? Vikeologist Plumbing 4 02-12-2010 04:12 PM
Gap in Corner Between Tub Surround and Bathtub? Howitzer Remodeling 12 09-17-2008 04:14 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 10:52 PM
