What Do You Put Between Backerboard And Drywall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 11:04 AM   #1
What do you put between backerboard and drywall?
We are remodeling our shower and have removed all the tile and cement board. We laid tar paper and hardibacker 1/2" board. We followed the directions and put a spacer between the backerboard and the shower pan. The tile book we have says to fill in the gap with silicone caulk before you tile.
***Will the grout stick to this or am I going to have to use a silicone grout on the bottom? We plan to use a 3 part epoxy grout with 1/8 spacing but the bottom spacing is 1/4.
We also left a gap between boards which I will tape and thinset.
There is a gap between the backerboard and the drywall. In some places it is less than 1/8 inch, and in some places it is up to 1/4 inch because of drywall crumble. This is at the sides of the shower wall, which will not be part of the actual wet shower enclosure. The tile work goes 6 inches or so past the enclosure.
*****What do I put in the gap between backerboard and drywall? Thinset, spackle, silicone? We plan to place tiles over this area so that they overlap the drywall by about an inch to hide the damage and seam. What would work best in this space before I lay tile down? Thanks so much for your help!
adventurefamily is offline   Reply With Quote
Old 02-09-2011, 08:47 AM   #2
Rewards Points: 5,336
You will caulk the bottom of the tile/showerbase connection as well as the corner.
Tape and compound the backerboard/sheetrock interface.
Ron
two questions about drywall job redblazerx Drywall & Plaster 3 03-06-2010 09:00 AM
Backerboard question shaggyb Tiling, ceramics, marble 4 01-31-2010 02:03 PM
BackerBoard not flush with drywall at seam. Request Solutions Mitch3GP Drywall & Plaster 3 09-28-2009 01:59 PM
Joining HardiBacker Backerboard to Drywall HanDIY Drywall & Plaster 1 07-26-2009 11:26 AM
bakerboard and drywall ontheroad1015 Drywall & Plaster 3 02-11-2009 07:17 AM
