What Could Be The Cause Of A Squeaking Noise In My Bathtub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 02:47 PM   #1
What could be the cause of a squeaking noise in my bathtub?
My bathtub makes a rather loud squeaking noise when I get in or lean against the sides.
It started off as a very minor squeak, but now it is rather loud.
I haven't removed the side panels yet. What could be causing this and how can I fix it?
____________________
www.aquaticaplumbing.com
aadambass is offline   Reply With Quote
Old 07-16-2013, 02:58 PM   #2
Some bath tubs are placed with a bedding material between the subfloor and the bottom of the tub. If this bedding material has shrunk over time then the tub could be shifting under load against the bedding. The purpose of the bedding material is to spread out the load from the tub. Large tubs need this extra support. Mine does this.
SCengineer is offline   Reply With Quote
Old 07-18-2013, 02:42 PM   #3
Rewards Points: 242
Or, no bedding material was used, and your weight is causing the tub material to flex. My friend just had a tub replaced in his mother's home. The plumbers were going to just set it and screw it. He happened to have had experience running remodeling jobs for a major contractor in a large city and nixed that and told them that he wanted the tub supported using a mortar base, which they grudgingly set about doing. Anyways, now his mother's tub is nice and solid.
I'm getting ready to install an acrylic shower base. When I set it on the floor and stand in it, it flexes by the sides, away from the bottom supports...so, it's getting a mortar base...otherwise, I think I'd be facing cracks and an eventual repair later down the road.
Just my two cents.
Ed911 is offline   Reply With Quote
Old 07-21-2013, 10:48 PM   #4
Rewards Points: 952
Do you have a warranty on your knees? I think this is where the noise is coming from.
cleveman is offline   Reply With Quote
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 09:05 AM
can you help me with this really odd noise? tuffluck Electrical 15 01-10-2011 05:35 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Help with ID'ing bathtub sound... DIY-Gal Plumbing 12 02-10-2007 05:45 AM
