Waterproofing Tiled Bathroom Wall/floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 05:14 PM   #1
Just call me Andrew
Rewards Points: 1,020
Waterproofing tiled bathroom wall/floor
I notice on home improvement shows, they sometimes put a plastic wrap (looks sort of like housewrap) on top of the duro-rock before applying the tile. I believe it's done for waterproofing. Not sure if they do it for the floor.
What is this membrane, and should I use it?
Also, when should or shouldn't I put Ditra on the floor?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 02-24-2010, 05:46 PM   #2
Military Mom of 4
Snav's Avatar
There are several water proofing membranes (aka - tile underlayment membranes) you can consider - each have slightly different specifications (you must read the product facts carefully - some are best with certain tiles and certain types of thinset, etc. Match the right product with the right materials so you don't have problems in the future.)
However - there is also something called 'Red-guard' - it is a paint-on water proof membrane that's for use on sheetrock and under tile thinset. http://www.custombuildingproducts.co...s/RedGard.aspx
I'd suggest you consider this, instead.
I've never used it before but definitely will for my bathroom I'm working on. . . and for all other tiling projects in the future.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
secutanudu (03-04-2010)
Old 02-24-2010, 05:53 PM   #3
There are a few products out there like kerdi and noble for waterproofing showers. Kerdi and ditra are both made by schluter. Keeps the substrate from ever getting wet and therefore keeps shower cleaner and smelling better, not to mention you never have to worry if water is getting past the cement board. These are not to be confused with redguard and other liquid applied membranes. Might not hurt for you to take a look and do some reading on the schluter website. Ditra is not necessary but does have some great advantages in many situations.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
The Following User Says Thank You to jaros bros. For This Useful Post:
Old 03-03-2010, 08:20 PM   #4
Just call me Andrew
The Schluter stuff looks very interesting. How well does it hold up? Or is that yet to be seen? How long has this stuff been in production?
Andrew
Old 03-03-2010, 10:34 PM   #5
Kerdi is a solid plastic (high-density polyethylene) sheet with a fleece material bonded to both sides (for the thinset to grab). Not sure how long it's been around the US, but I believe it came here from Europe.
I'd bet that it will last as long as necessary for you to get tired of the new tile you're installing!
Looking at their web site, I see that some of the state approvals are dated 2005. So it's been around at least that long...
houseinthewoods is offline   Reply With Quote
Old 03-04-2010, 07:38 AM   #6
ccarlisle's Avatar
Schluter's Kerdi membrane has been proven and around long enough for every bathroom/shower installer to be using it; no reason not to at least consider the benefits of a waterproof shower when you compare the investment in a new shower - let's say $8000 on average for a top-of-the-line natural stone enclosure.
Without waterproofing, that $8000 might last you 5 years before it may be time for a tear-out; however a waterproof shower will outlast the homeownera and we put that at 35-45 years. Now what's the best investment for comfort and possible resale?
The $ difference between the same two showers - one waterproofed and the other not - is about $1000 - so definitely worth it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 03-04-2010, 07:58 AM   #7
Just call me Andrew
I think I'll do the kerdi. My shower will be about 36" x 50" with a corner cut off for an angled door. Someone at Schluter said I could use the 32" x 60" shower pan and fill the 2" on each side with mortar. That sound like a good plan?
I don't think all the kerdi, corners, shower pan, etc will cost me more than about $600, probably worth it.
Andrew
Old 03-04-2010, 08:43 AM   #8
ccarlisle's Avatar
Yeah definitely worth it and a DIY project too. The Schluter shower kit is worth about $500 in stock sizes and avilable through HomeDepot. The key element is the drainage plane right down to the drain...
Old 03-04-2010, 01:14 PM   #9
Just call me Andrew
I was thinking about using the schluter shower pan, but using redgard instead of kerdi. Thoughts on that? Can I paint redgard right on the foam pan?
That will save me a few hundred dollars...not sure if it's worth it.
Andrew
Old 03-04-2010, 03:51 PM   #10
Military Mom of 4
Snav's Avatar
Yeah, you can always try to sculpt your own shower-floor out of mortar but that is such risky business. I'd suggest for you to use a shower pan, as well - and build on it.
If the cost is around 600 or so - then it's not bad. The average bathtub can cost 500 or so and a complete shower with surround can be more than that . . so its not too much more. Cost always is painful upfront, no matter what you're doing - but if you buy the right things and do it right then you can breath a sigh of relief when, in 10 years, you're not having to pay it out, again, to redo everything due to serious water damage.
Make sure you seal properly around all gaps and cracks in your plumbing and surfaces. It's amazing what kind of damage some water can do when it gets where its not suppose to be.
Old 03-04-2010, 05:44 PM   #11
I have no experience with Redgard, but I can't imagine that any liquid coating could block moisture nearly as well or as long as a solid sheet of polyethylene.
Old 03-04-2010, 05:52 PM   #12
Just call me Andrew
Yeah, The whole shower kit including the pan, drain, the fabric, edges and corners is only $500 or so. I'm gonna just go for the whole system.
I'll have to build up 2" on each side of the pan with mortar, which I'll cover with the paper. The instructional videos on the Schluter website are great.
Thanks for the advice to all. Better to do it right now than rip out my bathroom...again.
Andrew
Old 03-05-2010, 12:21 AM   #13
DO NOT use Redgard instead of Kerdi. It isn't going to work.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 03-05-2010, 06:11 AM   #14
Just call me Andrew
Bad experience with RedGard?
Andrew
Old 03-05-2010, 09:38 AM   #15
Just call me Andrew
I am reading that Schluter recommends Unmodified thinset. Does this mean i should NOT add a mold retardant additive to the mortar?
Andrew
Piping Layout for New Bathroom structman Plumbing 2 02-23-2010 05:24 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 11:44 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
