Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-23-2012, 06:28 PM   #1
walnut slab contertop Installation = Need Help
i am mounting a 98"x23" walnut slab about 2" thick. what is the best way to frame the support for the countertop to float across the 98" span? there are no cabinets or boxes underneath?
thanks
freez is offline   Reply With Quote
Old 11-23-2012, 07:43 PM   #2
Super Moderator
This is going to be supported by some sort of bracket?
How important is the appearance? What kind of look are you going for? Wood?---Metal?
Do you have any pictures of something that you like?
Old 11-23-2012, 10:57 PM   #3
i can get pictures soon(too much in the way)
im doing the structure holding the counter out of 2x4's
i put a 2x4 ledger on back wall which 68". the right side of the counter (facing it) has a 24" wall to support that side. the left side wall is on a 45 degree angle but a ledger on that wall can support left side
the front of the counter (closest to you as you stand at a sink etc) is 98" wide
should i just build a 'box' out of 2x4's and block it in?
will a 2x4 support the front of the walnut slab?
Old 11-24-2012, 06:52 AM   #4
Super Moderator
Yep---a 2x4 has plenty of strength to hold up a counter and all the thing on top--
Old 11-24-2012, 10:23 AM   #5
whats the best way to fame it. the front edge 4x6 can just screw into the side ledgers or do the have to rest on top of something?
Old 11-24-2012, 11:12 AM   #6
funfool's Avatar
thanks
I picture this as a nice piece of wood, and can see how you can support it with no cabinets underneath... but why?
Now you say will be a sink mounted in it?
What will you do to cover the plumbing, what will the free space under it be used for?
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
Old 11-24-2012, 11:13 AM   #7
Super Moderator
Get us a sketch of the area and the size of the top---I'm a cabinet maker and there are others here with good skills and creative ideas---
You will get the most accurate suggestions if we know exactly what you are working with.
Also--what tools do you have for working wood?
Old 11-25-2012, 10:56 AM   #8
AHH, SPANS!!!
it will need to rest on top and two 2x6 nailed together work much better than one single 4x6 for horizontal span purposes...
hand drive is offline   Reply With Quote
Old 11-26-2012, 12:33 AM   #9
thanks gentlemen
Old 11-28-2012, 04:47 PM   #10
heres the walnut top. you can see the 4x6 stringer on front edge. it will get a walnut finish peice over it HOWEVR i wish there was a way to not have that there. but without it i think the middle may sag overvtime
ideas on a more hidden way?
i can move it in further perhaps. not sure how far
walnut slab contertop Installation = Need Help-image-2015169357.jpg   walnut slab contertop Installation = Need Help-image-1891674471.jpg   walnut slab contertop Installation = Need Help-image-1544718566.jpg
Old 11-28-2012, 06:21 PM   #11
how about embedding a piece of steel angle into the bottom of the slab lengthwise.
Old 11-28-2012, 06:25 PM   #12
Items wanted: Time
what about some more walnut to serve as a screen for the plumbing and a supports for the shelf?
NiNe O is offline   Reply With Quote
Old 11-29-2012, 01:02 AM   #13
this was the plan, but it really takes away from the live edge of the tree. so i thought there were some alternatives. i removed the front ledger today and it is plenty supported. but i wonder if it will sag at the front over time. its 2.125" thick so not sure
looks alot better with nothing there. i dont mind the chrome plumbing.
Old 11-29-2012, 01:21 AM   #14
thats an idea! didnt think of that.
thin but should add rigidity. thanks!
8*6 concrete slab novice25 Concrete, Stone & Masonry 2 06-19-2012 12:31 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
What's Happening on my Slab? chew Flooring 6 04-10-2011 01:11 PM
Pouring Patio Slab and Post Footings Question average_male Building & Construction 17 09-27-2009 02:44 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
