Walk-in Shower Dimensions - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 10:51 PM   #1
Rewards Points: 38
If I have a shower that is 48" across, would it be feasible to make it a walk-in shower with a 24" glass panel at the end where the showerhead is and a 24" space at the other end for entering the shower? Is that too narrow for the glass panel, allowing for water to escape onto the bathroom floor? What about if it's a rain shower? Thanks for your advice
QCKiwi is offline   Reply With Quote
Old 10-06-2013, 01:53 AM   #2
DIY staff
Rewards Points: 7,174
without a door or curtain,water will escape---sorry---
Old 10-06-2013, 02:00 AM   #3
Rewards Points: 1,016
Yeah, too narrow methinks even with a movable panel extension.
____________
Vince
Old 10-06-2013, 11:44 AM   #4
Rewards Points: 38
I figured as much. Had hoped that with a rain shower, it would be enough. So what would you suggest I do here? I want the dividing wall between the shower and bath to be half-height allowing more light into the shower and also so that the wall can be used as a shelf. It might be weird to have a glass panel and shower door on the front of the shower while leaving the space above the wall open? Maybe I will have to glass the whole shower in?
Old 10-06-2013, 05:28 PM   #5
DIY staff
Yep---water will end up getting out----try making a temporary wall using Styrofoam and tape----that's a cheap way to see if it will work----I tried it on a much bigger shower than that and ended up adding a door---
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Suggested Shower Bench Dimensions spQQk Building & Construction 5 03-07-2009 08:05 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
walk in shower; how to? nap Building & Construction 5 07-20-2008 12:24 PM
