Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-05-2013, 02:37 PM   #1
Vikrell Tub Setting Recommendations
I'm getting ready to set my tub in my bathroom in a few days. It's a Sterling Accord tub with the "caukless" three piece wall kit. They recommend using their provided felt pad for install, or if one is not available, to set in a base of mortar. I'm assuming since they mention the latter in official literature, that doing so would not void the warranty, but why the felt pad as the number one suggestion? The base of this tub is VERY stout and has reinforced ribbing and really sturdy support feet. Would I still be susceptible to creaks down the road if I forewent the mortar mix?
mgh-pa is offline   Reply With Quote
forced air furnace fan setting won't work turkish777 Electrical 31 03-14-2012 01:28 AM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 09:22 AM
Manifold pressure setting on new furnace kb3ca HVAC 21 11-16-2010 06:00 PM
Freezer not cold enough at "normal" setting... skipjack Appliances 2 02-01-2010 04:10 PM
Least expensive Programmable Thermostat for home with automatic vacation setting Studly HVAC 2 12-15-2009 08:18 AM
