Venting Bathroom Out Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 11:44 AM   #1
venting bathroom out wall
Hello,
I have an old double brick house with a flat roof. I want to vent my bathroom out the wall to avoid putting a hole in the new roof membrane. The problem is that the wall is not insulated leaving me about 2 inches of space between the inside brick and plaster (the plaster is furred out on 1x2s). Is there a skinny fan out there somewhere? I would prefer not to build the fan box out of the wall for aesthetics. When I talk to locals in the hardware stores they look at me like I am crazy, but every house is this entire city is double brick, flat roof, no insulation so someone has to have tried this.
thanks a lot.
mrtmills is offline   Reply With Quote
Old 07-13-2009, 06:45 AM   #2
Some local codes allow that, some do not, check local authority.
Old 07-13-2009, 08:18 AM   #3
Rewards Points: 264
An HVAC supply house will have a fan, lots of guys use Greenheck, but that is just one brand option. A plumbing or HVAC supply house will have more options and maybe some suggestions.
Definitely check the codes. You can spray foam the cavity to help seal it.
I understand about the visual aspect, but if you can get over that there will be more common options in the wall mounted style blower.
7echo is offline   Reply With Quote
Old 07-13-2009, 08:52 PM   #4
Thanks, I will check the code, and the HVAC suppliers.
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 11:34 PM
Look at this pic, and tell if you would do this or not - bathroom wall. J187 Remodeling 19 04-25-2009 08:58 PM
bathroom shower in basement along foundation wall jeeper Building & Construction 1 04-16-2009 08:20 PM
bathroom wall tile TonyD Remodeling 5 04-09-2008 08:55 AM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 08:26 AM
