Vapor Barrier Behind Acrylic Enclosure? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 04:51 PM   #1
Ok so I've posted a few questions about my bathroom remodel, here is my latest:
Before I installed my acrylic tub/shower enclosure, I put up a vapor barrier over the studs/insulation. Then I installed my tub, no problems. However, my shower enclosure is a 3 piece, direct-to-studs kit (cheap, I know, but it's all I can afford right now). The main method of adhesion is to use adhesive on the studs. However, my studs have my vapor barrier over them, so I would essentially just be gluing my shower walls to 4 mil plastic sheets held up by staples, which doesn't seem like it will work too well. Any ideas?
Thanks!
csanberg is offline   Reply With Quote
Old 04-12-2011, 09:48 AM   #2
Remove the plastic from the front of the studs.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 04-12-2011, 11:24 AM   #3
Thanks so much for the well-articulated post.
If you are suggesting going sans vapor barrier, please explain why. Is this an antiquated concept?
Old 04-12-2011, 10:19 PM   #4
It's more like a common sense concept. If in fact the installation instructions call for attaching the surround to the studs directly, one would have to assume that's what it means - directly to the studs.
Stud spacing when installing enclosure not enough az_r2d1 Building & Construction 23 03-26-2011 10:01 PM
Oil- Acrylic Primer- Oil? blue_fox Painting 3 06-23-2010 11:32 PM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 09:38 PM
Steps to ripping out acrylic shower stall enclosure and covering with tiles? Bacardi 151 Carpentry 3 10-30-2007 11:35 AM
Need help picking an outdoor enclosure coyote556 Electrical 13 08-06-2007 04:24 PM
