Vanity/ Countertop Measuments - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 04:53 PM   #1
Rewards Points: 170
Vanity/ countertop measuments
we will be removing our old vanity that is fit between two walls with a wall in the back as well. The opening is 48", which is standard, however the precut countertops in store say they are 49" wide. How do I account for this extra 1/2" overhang on each side?
diyer111 is offline   Reply With Quote
Old 08-26-2013, 05:26 PM   #2
Framing Contractor
Rewards Points: 126
You really can't account for it. Those cultured marble top vanities are designed to not push against the wall on either side. We have occasionally used them where one side sits against the wall. We installed a wood filler to the vanity in order to keep the top centered.
Have you considered building your own top? You could still use a stock size vanity, and then fabricate a top from laminate or other materials.
sixeightten is offline   Reply With Quote
Old 08-26-2013, 10:38 PM   #3
I used to cut them to fit and then belt sand the edge smooth. I usually had to scribe them to fit crooked walls.
Old 08-27-2013, 01:33 PM   #4
K&B Designer
Live_Oak's Avatar
Sometimes you can just cut a slot in the drywall and slide it in. If the depth of the alcove is enough where the edge won't stick out, repairing the drywall can make it look OK. It does have a chance of having cracking of the drywall there in the future as the home shifts though.
Live_Oak is offline   Reply With Quote
Old 08-27-2013, 04:27 PM   #5
Bill Kearney
Rewards Points: 1,174
This. Just scribe and trim them to fit. Or call in a counter installer and get something nicer than the prefab stuff at the box stores.
You might be surprised how inexpensively it can be done. Especially if you find a remnant of a slab. They often have left over sections from other jobs. You just have to open up your preferences a little and be prepared to consider alternatives based on the cost savings. Shop around a bit, but know that remnants don't hang around. If you find one that works you really need to jump on it.
We've got a really nifty looking Giallo granite going into our laundry room thanks to remnants from another customer's job. I'm getting it for little more than cost to fabricate and install it.
wkearney99 is offline   Reply With Quote
How to build/attach wall hung bathroom vanity NewHomeDIYGuy Carpentry 13 12-28-2011 02:17 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
