Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 05-19-2011, 11:00 AM   #1
Using sanded grout for spaces less than 1/8"?
Hello,
I just finished laying floor tiles in my bathroom. I am ready to grout it. I used 1/8" tiles spacers and will be using sanded grout which I already purchased.
However, due to my bathroom shape, during floor tiling I ran into some problems and had to put couple of tiles with space less than 1/8". I don't want to buy a bag of unsanded grout just for two lines between tiles.
Do I have to spend $10 for sanded grout just to grout two lines and then throw it away? And in general, why can't I use sanded grout for spaces less then 1/8".
sukhenkoi is offline   Reply With Quote
Old 05-19-2011, 11:45 AM   #2
Hey Sukhenkoi,
You shouldn't have to go and get a non-sanded grout to fill those small grout lines. When you are grouting just be sure fill them and go over them until they good. If you don't think that will work you can get the matching grout in a caulk tube as a non-sanded and squeeze it in. - Gregg
gotogregg is offline   Reply With Quote
Old 05-19-2011, 02:12 PM   #3
Gregg,
Thanks a lot. This is a way to go for me. This is an approach I was thinking about.
Thanks a lot again.
Igor.
Old 05-19-2011, 07:19 PM   #4
Tileguy
Bud Cline's Avatar
You'll be fine, just may have to use a little extra effort to fill the smaller joint but it will fill in with the soup as you clean the grout.
Even though the claim is readily made that "matching caulk" is available the truth is the caulk probably won't match perfectly and the texture will be different so I wouldn't suggest you use the caulk to fill a grout joint. In a corner where there is a change-in-plane the mismatch would go unnoticed but on a flat plane it will likely show in contrast to the grout.
Old 05-19-2011, 08:03 PM   #5
Thanks Bud!
Actually, the tiles with smaller spaces are located behind the toilet and almost invisible. But I'll still try to use grout first. I'll just push it a little harder.
Old 05-19-2011, 08:42 PM   #6
Tileguy
Bud Cline's Avatar
After the grout has been spread and set for a few minutes you will use a damp sponge to scrub and dress the joints. The sponge will begin to pick up some sludge and this sludge will easily fill the narrow joints for you.
The Following User Says Thank You to Bud Cline For This Useful Post:
sukhenkoi (05-20-2011)
Old 05-20-2011, 07:56 AM   #7
Bud,
This is not my first tiling project and every time after I finish, the grout does not look very even. It looks ok, but not pretty. I always follow the instructions; I watched some videos on the internet, but still can't make it look really good and even. Are very any tricks to make grout look really nice? One of my co-workers uses popsicle sticks to help grout to spread more evenly in spaces. But I am not sure I want to do that.
Old 05-20-2011, 05:51 PM   #8
Tileguy
Bud Cline's Avatar
People use Popsicle sticks, tooth brush handles, broomsticks, god only knows what people come up with. There is nothing wrong with any of that I suppose but it is all totally unnecessary.
A simple damp sponge will do all of that in a whiz and deliver perfect looking joints every time. I don't understand why so many people try to re-invent the wheel all of the time.
Sanded or unsanded grout for the shower surround wall tiles? nitting Tiling, ceramics, marble 10 11-30-2012 09:45 AM
Can I use sanded grout for wal tiles? sukhenkoi Kitchen & Bath Remodeling 2 05-13-2011 07:33 AM
Can i apply unsanded grout over sanded grout? Philj Tiling, ceramics, marble 1 04-19-2011 08:58 PM
Sanded grout used by mistake with marble nihalh Flooring 3 02-05-2010 12:54 PM
Sanded grout for 1/16th space Kuuyku General Discussion 5 07-05-2008 10:29 AM
