Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-09-2012, 12:34 AM   #1
Question
Upstairs fiberglass shower leaking - help?
I just discovered that the upstairs one piece shower stall (30 years old) has been leaking into the room below and the sheetrock is black and moldy in about a 1 foot square area.The shower valves are on an exterior wall. I want to redo this shower anyway. I wasnt going to do this until after the Holidays. Should I cut out the effected sheetrock downstairs and see if I can get to the source of the leak/ and or just get out the sawsall and get to work?
Learninghow is offline   Reply With Quote
Old 11-09-2012, 03:30 AM   #2
Super Moderator
Sure--cut that out----might be a simple drain fix----you have to fix the ceiling anyway---------
Tags
fiberglass stall, shower leaks
Tile shower surround above fiberglass shower Gregghea Tiling, ceramics, marble 3 01-28-2011 08:39 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Fiberglass Shower - can they be refinished somehow? cody21 Remodeling 0 04-05-2010 12:04 PM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
