Undermount Kitchen Sink Installation Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-03-2015, 09:22 AM   #1
ZZZZZ's Avatar
Rewards Points: 784
Undermount kitchen sink installation question
I'm getting ready to install a copper undermount sink I bought at that Big Orange store. It's going under a butcher-block style wood counter that I fabricated.
My question is how best to secure the sink to the underside of the counter. The sink came with a set of 8 clips and threaded inserts. The instructions are very vague (what a surprise) but it seems to me the instructions are written to install the sink under granite or a similar man-made substitute. The instructions say to drill holes, insert the threaded plugs and then screw in the clips to hold the sink. Okee Dokee
I'm just wondering if, with a wooden countertop, the sink would hold better if I didn't use the threaded inserts and instead just used some short and fat wood screws and screwed the clips directly into the underside of the countertop..
Any thoughts anybody? Thanks.
ZZZZZ is offline   Reply With Quote
Old 08-03-2015, 09:36 AM   #2
Rewards Points: 3,776
I install a 2x3 or 2x4 frame for the sink to sit on. The counter top rests directly on to the sink. The sink flange is silicone caulk to seal it.
If the sink needs to be removed, the frame can be unscrewed under the sink base cabinet.
Wood counters next to the sink are a short term counter.
Ron
B. Franklin 1759
Ron6519 is online now   Reply With Quote
The Following User Says Thank You to Ron6519 For This Useful Post:
ZZZZZ (08-03-2015)
Old 08-03-2015, 09:45 AM   #3
ZZZZZ's Avatar
Rewards Points: 784
I'm not too concerned about the wood counter itself. It's not "food-safe". It's topped with 5 coats of poly. The end-grain at the sink edge and the underside near the sink will be coated with marine spar varnish.
Old 08-03-2015, 10:01 AM   #4
I did an oak 5/4" thick top for the bath vanity. Used multiply coats of marine poly. This had a drop in sink. After 5 years it was replaced due to discoloration. It was only a 25" wide top so no big deal.
This was in 1981-1985. Maybe the poly is better now.
Ron
B. Franklin 1759
Farmhouse sink install question Master Brian Remodeling 1 10-22-2013 02:43 AM
Installing new Vent pipe for kitchen sink dtweiss74 Plumbing 1 10-21-2012 02:11 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 02:39 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
