Under Counter Sink Installation - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 09:27 AM   #16
Civil Engineer
Rewards Points: 4,514
I have installed several sinks in granite, and had a couple installed for me. I also have never used the 2 cm granite, only 3 cm (1-1/4 inch), which is a pretty common thickness. In all cases, the granite was drilled by a granite shop, and threaded inserts were epoxied in place. The drill holes were templated off the actual sink to be installed. Special stainless steel clamps hold the sink in place, and the clamps are held in by stainless steel bolts that use the threaded inserts.
I have read several posts indicating that 2 cm granite is too thin to accept threaded inserts, and requires a plywood subbase to attach the sink to. Nothing suggesting an install such as what you have, but perhaps the technique you showed is acceptable based on local practice.
Laundry sink for 24" unit that doesn't require a counter top mfrenette Building & Construction 0 02-17-2013 02:20 PM
Re-attaching a sink pmarc Building & Construction 1 07-21-2011 04:19 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
Vessel sink fits loose on counter top jam12 Plumbing 3 11-20-2008 06:02 PM
Sink Installation - Please help again! iOsiris Plumbing 17 08-08-2007 07:14 PM
