Under Counter Sink Installation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-12-2013, 09:18 AM   #1
Unhappy
under counter sink installation
Does this look right to you?
Our contractor has installed our sink using shelf brackets and a 2x4 with door shims. The counter is 2cm granite without any plywood backing (which I am not very happy about either). It looks kinda mickey duck to me.
beaker020 is offline   Reply With Quote
Old 07-12-2013, 09:26 AM   #2
Rewards Points: 13,750
Looks like a poopy install to me.
Those shelve brackets are useless for that job.
Not even sure how you would install the drain strainer set up like that.
beaker020 (07-12-2013)
Old 07-12-2013, 09:55 AM   #3
Rewards Points: 34
Wow. That's just wrong. What does the top side look like? Was the installation done by a stone contractor or someone else?
Dan
djlandkpl is offline   Reply With Quote
Old 07-12-2013, 10:24 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,866
AGREE ^^^^^.... Looks very sloppy..... and with only 2cm.... not very sturdy/supportive.
The front of the sink at maybe only 4" wide can be prone to cracking.... did the granite guys epoxy in a steel reinforcement rod... (actually not sure you can do that with 2cm.)
I actually have never done 2cm.... and I thought 2cm was supposed to have a plywood (recessed if granite is not lipped out to 4") support???
What kind (name) of granite. The stone streangth varies quite substantially with type of granite.
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 07-12-2013, 11:07 AM   #5
The granite is "Volga blue"
the granite was installed by the stone company but the sink was installed by the cabinet contractor. The topside looks OK.
no rods.
Old 07-12-2013, 11:59 AM   #6
Rewards Points: 34
I'm going to make some assumptions.
The counter contractor used shims or blocks to raise the counter top 2cm to get the front to overhang the cabinets correctly.
The counter should have had threaded holes installed for the sink so clips could be used to hold the sink to the bottom of the counter. This assumes the counter contractor took the sink during templating.
The cabinet contractor installed the sink this way 1) didn't know how OR 2) added the supports because unsupported 2cm granite will not support the weight of a full sink.
I have no experience with 2cm but to me, it's not strong enough without backing. If it wasn't in your contract, you might be out of luck. If it were my house, it would all be coming out to be redone. You're making a huge investment in your kitchen and it should be done correctly.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
Old 07-12-2013, 01:31 PM   #7
MarginallyQualified
Rewards Points: 2,464
I really thought I had seen it all.
I was wrong.
Old 07-12-2013, 02:46 PM   #8
2 CM is only .065 thick!
Not even sure how they could have epoxied in an insert with it that thin.
Old 07-12-2013, 03:07 PM   #9
2cm is 0.65" about 2/3 of an inch but you are right, they generally don't put inserts into 2cm. They put a plywood backing and screw the mounts into the plywood.
The 2x4 you see there is holding up the front of the sink, with the help.of door shims. And silicone sealer.
The installer says I'm being too fussy," its always done this way. "
Old 07-12-2013, 03:09 PM   #10
Unhappy
(I'm the other half involved with this kitchen dilemma)
I'm wondering how it's going to hold the weight of a garburator?
BCSuzie is offline   Reply With Quote
Old 07-12-2013, 03:20 PM   #11
Rewards Points: 34
Can you post some pics from the top side of the sink? So there's nothing holding the rim of the sink to the counter?
Water weighs about 5 pounds per gallon. Fill both sinks add the weight of the garbage disposal and that 2x4 on its side is going to flex. Then you've got problems.
Do you have a contract that gives you some power to get them to redo it?
Dan
Old 07-12-2013, 03:27 PM   #12
These are the only other pics I have of the sink installation right now. Not sure if this'll help with ideas or not...
under counter sink installation-img_0370.jpg   under counter sink installation-img_0373.jpg
Old 07-12-2013, 03:28 PM   #13
The sink is mounted below, so there's really nothing much to take a picture of from the top... There is a clear silicone of something along the edge of the sink.
Old 07-12-2013, 04:47 PM   #14
Rewards Points: 34
The only idea I have is to have it redone. Hopefully someone will come along with some suggestions.
Dan
Old 07-13-2013, 07:54 AM   #15
firehawkmph's Avatar
Rewards Points: 1,884
I have done a lot of kitchens, but never used the thin granite. Everything around here is 1 3/16". The granite shop that does our fabrication and installs always mounts the sinks. For a stainless steel sink, they use some kind of strong adhesive and clamp it into place from above overnight. Never had a problem. For a heavy sink like a granite farmhouse style or cast iron, I build a 2 x 4 frame with a 3/4" furniture grade plywood top on it for the sink to sit directly on. I cut holes large enough for the sink strainers to be installed with room to work, and also cut an access in the plywood for the faucet hookups. Never seen anything like whats in your pics. That's a pretty poor job, and I don't believe you're being too picky.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Laundry sink for 24" unit that doesn't require a counter top mfrenette Building & Construction 0 02-17-2013 01:20 PM
Re-attaching a sink pmarc Building & Construction 1 07-21-2011 03:19 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Vessel sink fits loose on counter top jam12 Plumbing 3 11-20-2008 05:02 PM
Sink Installation - Please help again! iOsiris Plumbing 17 08-08-2007 06:14 PM
