#1 |
(un)bending laminate countertop
So I'm adding a breakfast bar to the kitchen, and naturally want it to match the existing countertops. They are your run of the mill laminate countertops with backsplash.
The breakfast bar will not be against a wall, so I want the nice rounded edges on both sides. To get a piece custom made is way overpriced. What I did was purchase a piece of the same countertop, and i want to turn down the backsplash side so the whole piece is flat with the rounded edge on both sides. The countertop is actually 3 pieces, the base, the backsplash, and a squared off piece that they both are attached to, all covered with the single piece of laminate. What I have done is cut out the piece in between so I can turn down the backsplash side to make one flat countertop. Now I need to heat the laminate to turn it down and flatten it. I tired the hair dryer route, but by the time I got from end to end it was cool again. I'm thinking i'll need to use an actual heat gun or a torch to get it hot enough to bend the whole thing down at once, but ive never done it so im concerned about ruining it since I have pretty much no margin for error. Thoughts? Thanks in advance! Here is a pic of the piece ready to be bent:
#2 |
That is a post formed top, done in a very controlled atmosphere with expensive machines. Formica will not stand the kind of heat you are talking about. For a short piece it might be possible for a DIY, but not for a long piece. Invite 6 guys with heat guns over to help, but only use on the low setting.
#3 |
gonna stress at the seam
The older I get the better I was |
#4 |
(un)bending laminate countertop |
#5 |
Xtreme DIY'r
That seam really sticks out, even in the little pic
And will be a failure point I imagine |
#6 |
I am amazed that you did as well as you did.
Post formed counter tops are usually made from (VT) very thin not offered in the full assortment of laminates. If your not happy.... you could salvage most of the top if your desired dimensions allow...by cutting off round edge and install some wood or solid nosing at perimeter.
| The Following User Says Thank You to Big Bob For This Useful Post: | packer_rich (06-07-2012) |
#7 |
Tileguy
(un)bending laminate countertop![]() ![]() ![]() ![]()
#8 |
Just did this today with boiling water trickled along the joint. Worked like a charm, but the line is still very visible. Maybe gonna try a towel and iron tonight to flatten it out more.
| Display Modes | |
| Where to put seam in laminate countertop | tigereye | Kitchen & Bath Remodeling | 2 | 01-17-2010 09:49 PM |
| Countertop - Epoxy Granite over Laminate | sdrachel | Remodeling | 1 | 09-19-2009 07:15 AM |
| Laminate Countertop in Bathroom Least Expense? | houston | Kitchen & Bath Remodeling | 2 | 02-01-2009 01:19 AM |
| laminate countertop ? | jdixon | General Discussion | 9 | 03-19-2008 10:15 PM |
| Laminate Kitchen Countertop | Ken Johnson | Remodeling | 2 | 11-21-2007 01:10 AM |
