Two-levelled Kitchen Island With Breakfast Nook - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 09:01 AM   #1
Two-levelled kitchen island with breakfast nook
Hello,
I am remodelling my kitchen and part of it involves a small two-level kitchen island with a seating area. Basically it will consist of a slide-in range, with a 15" and 9" cabinet on either side, then a raise behind with about 15" of counter space for the eating area. It will be similar to the picture below, although the stove is a slide-in range and there is no room behind the stove before the raised level.
Unfortunately my kitchen designer did not order any sort of wall for the raised counter to sit on, which means I will have to build it myself. I was wondering if anyone has any suggestions in how to do this easily while using up the least amount of floor space? And also something that looks a little nice? The designer did include a large sheet of veneer to match the cabinets for the back of the island. Any design/building ideas would be greatly appreciated!
Thanks!
laughingduck is offline   Reply With Quote
Old 02-09-2010, 09:06 AM   #2
tell yor designer to earn their fee and make it right
The older I get the better I was
Old 02-09-2010, 09:10 AM   #3
She's a Home Depot designer so I'm not paying her. She said she could order the part but it'll take another 4-6 weeks to get here and I'm not prepared to wait that long to have my kitchen back! I have someone coming in to tile tomorrow and was hoping to have the wall built by then...
Old 02-09-2010, 09:20 AM   #4
are you tiling the top of the bar section?
Old 02-09-2010, 10:01 AM   #5
jlhaslip's Avatar
Rewards Points: 2,820
The kitchen design/layout should have the spacing and specs for the eating bar.
For its construction, use 2 by material and sheathing of some sort. Glued and nailed.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-09-2010, 08:00 PM   #6
firehawkmph's Avatar
Rewards Points: 1,902
Ld,
I would build the wall out of straight 2 x 6's. I would cover the back with 1/2" plywood before the veneer to provide some strength and stability. After you put the veneer on, you could make up some frames out of 1x4 vertical rails and 1x6 base and break up the back a little. If you lay it out right, your vertical pieces will be where you fasten your corbels if you are using them.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-09-2010, 10:54 PM   #7
I agree with jlhaslip. There should be specs if it was designed that way in the first place. HD software can isolate that island by itself.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-10-2010, 11:03 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
You also want to check on the clearances from your drop in range to the vertical wall behind it.
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 01:08 PM
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 09:44 AM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 09:19 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
Jacking up a sagging breakfast nook Thomas Stillwell Building & Construction 2 09-21-2008 08:47 PM
