02-19-2011, 09:50 PM
#31
Tileguy
Tore out ALL old shower, Help redo
I think it is basically the same drain and the same procedure you want to do but the thing is the liquid membrane that bothers me. That Laticrete product isn't the same as the Redgard. They are probably using Hydroban. What is the mil-thickness recommendation when doing it that way? There is a minimum I'm sure.  I've used a lot of Redgard but I certainly wouldn't trust it in that type of application but it is your decision.
The vinyl pan liners come 30mil and 40mil. Doubt you could ever build Redgard like that. It would also need a week or more to dry before covering it with the second cement application so that it wouldn't re-imulsify under the moisture of the second cast.
The whole idea scares me.
02-19-2011, 10:07 PM
#32
I took the redguard back, its gone.
I have hydroban now and their accompanying cloth for the joints.
Could I use the Kerdi drain instead of this EBBE I got? and still do the hydroban style install? or does kerdi drain require all their other crap?
I only mention the kerdi drain because they have a oil rubbed square cap, like this EBBE I got
Except I would have to order the kerdi drain online and delay this project again, but I want to do it right.
Thanks for your time!
02-19-2011, 10:37 PM
#33
Tileguy
Now you're talkin'.
Yup!
These guys are pretty quick and they ship direct from Schluter in New York.
http://www.tile-experts.com/products.asp?id=54
02-19-2011, 11:48 PM
#34
Thanks again Bud....
Sorry takes me so long to grasp this...call it e-stupidity.
SO.....IF I go the kerdi drain route (now that I will have that delay, I might just go the kerdi membrane now)...but kerdi drain and hydroban, does that kerdi drain do its final install on that first bed of 'sandmix'?
ala-wether I go kerdi matt/membrane OR hydroban, both of those only require the single/first layer concrete (sandmix) bed, correct?
02-19-2011, 11:59 PM
#35
Super Moderator
Correct--one mud bed--Kerdi drain is used with the mat or Hydroban--Mike--
02-20-2011, 12:13 PM
#36
Tileguy
Allow me to recap.
Hydroban is way way way (that's three "ways") better than Redgard.
My biggest problem when using either is the clamping drain. Just don't see how that would work with Redgard. The drain would quickly damage the Redgard when being assembled. If the drain assembly should move slightly I would fear damage at the dish juncture also. Redgard also blushes days after installation when moisture is applied to it. I don't think anyone knows just yet what issues that may raise if any.
Hydroban on the other hand is a better product from the standpoint of its ability to bridge and fill spaces up to 1/8". It will build quickly and in my experience doesn't seem to develop pin holes like Redgard does. I also would have more confidence in the Hydroban under the clamping drain.
I still wouldn't use either one for a pan liner, not just yet anyway. And with both you still have to cast a second cement floor.
Using the KERDI Drain there is only one cement casting. And yes the cement does need to be packed in under the drain. With the KERDI Drain the Hydroban would be an easy installation. I still wouldn't do it.
KERDI Mat is the only way to go with the KERDI Drain in my opinion.
02-20-2011, 12:46 PM
#37
Bud...remove redguard from your vocabulary, I have returned it, its gone, never to be seen or talked about again
This method here is a 'traditional' type right?
http://www.ontariotile.com/preslope.html
Where you basically are building 2 mortar beds, with a membrane underneath-but that membrane in this TYPE of shower pan can only be Poly, not kerdi mat, not hydroban?
02-20-2011, 12:54 PM
#38
02-20-2011, 01:02 PM
#39
Tileguy
Yow I got that part already but others lurk and I just want to be sure.
Correct. Why do you think I've been trying to discourage your thinking? You see the thing is...Custom Building Products says Redgard (there's that word again) can be used in that manner but a whole swarm of pros say NO-WAY. The technique also does not appear in any of the industry sanctioned methods either. Custom Building Products has a tendency to want all of their products to be one size fits all and in my opinion they have been known to stretch the truth from time to time.
The Ontario Tile drawing is absolutely correct.
02-20-2011, 01:17 PM
#40
Gotcha!
But the questions continue
So if I go the 'traditional' route, I need to by the PVC membrane (which looks like home depot sells it for $200!!!! http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 I don't need that much, thats all they sell....sucks I have all these home depot gift cards).....AND if I do this 'traditional' method, I am still going to hydroban the entire shower because that PVC is only protecting the PAN, correct?
Kerdi is sounding more cost effective at this point
Oh....IF i got the kerdi drain route, didn't I read something about needing a large space around the drain? I only have about 2" between the drain and that short side of the foundation as shown here
02-20-2011, 01:27 PM
#41
Tileguy
No No No No! They want to sell you fifty feet of the stuff. What the hell you gonna do with fifty feet of shower pan liner? Two hundred bucks???
Go to a plumbing supply house and they will cut-off any length you want and they will have stock 5' wide and 6' wide if you need it. Stay the hell out of Home Depot.
This is true.
Even with the picture I ain't following what you are saying. That thing in/near the middle isn't the drain?
Try again.
02-20-2011, 01:31 PM
#42
I have homedepot gift cards, and I am broke, hence the trips to the depot...but I wasn't about to drop $200 on pvc that will go in the trash (remainder)....will try and find time to get to tile shop for piece I need, IF I don't go the kerdi route.
Kerdi drain, didn't I read that Kerdi drain needs extra space around the drain?..like more space around it than other drains? maybe I am confused, which is entirely possible
02-20-2011, 06:01 PM
#43
Tileguy
You said that, I get it.
The KERDI Drain has a flange on top that is larger than other shower drains. This flange is there to receive the KERDI Mat to promote proper drainage. This flange however will end up under the tile and only the smaller 4" drain grate will be visible.
You didn't answer my earlier question which was:
Even with the picture I ain't following what you are saying. That thing shown in/near the middle in the picture, isn't that the drain? If it is then you have plenty of room for a KERDI Drain.
I can tell you the liner for $200 at the Depot is at a cost of $1 per square foot whereas that same liner in a lessor amount is going to cost around $5 per square foot but even at that it would be a lot cheaper to go somewhere else to buy only the amount of liner you need. I can't imagine what HD must be thinking, that $200 offering just doesn't make any sense. I don't think they know what they have there or what it is for.
02-24-2011, 02:29 PM
#44
update? I've gotten caught up in this unfolding. Perhaps the OP is busy building his shower instead...
02-24-2011, 08:28 PM
#45
Tileguy
Maybe he finally ran out of Gift Cards!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
