Tool For Cutting Tile When Laying Kitchen Backsplash? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 11:38 AM   #1
Tool for cutting tile when laying kitchen backsplash?
I am about to tile my kitchen backsplash with 12x12 mesh backing mosaic stone tiles. I am going to use a manual tile cutter for the straight cuts but do not know what tool to use to notch out the outlet holes. I was thinking a dremel with a diamond wheel or maybe an angle grinder with a diamond wheel? Any thoughts?
maj0819 is offline   Reply With Quote
Old 07-08-2014, 12:12 PM   #2
DIY staff
Rewards Points: 7,174
An angle grinder with a diamond blade will work fine---
Wet cutting often causes the tiles to fall off of the mesh---if you do wet cut--cover the tiles with wax paper to reduce the amount of water that gets to the mesh.
Old 07-15-2014, 08:02 AM   #3
Rewards Points: 644
Plan the lay out then rent the wet saw. It is necessary cost. For mid field cuts, remove the tiles that go over an outlet, eg, then fit each piece. GFI outlets have cover screw holes at different places.
carpdad is offline   Reply With Quote
Old 07-15-2014, 12:08 PM   #4
Rewards Points: 144
Angle grinder with a diamond blade is the way to go as mike suggested.Get a pair of tile nibblers for the corners so you don't have to overcut the corners of the opening to much.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
oh'mike (07-15-2014)
Tile Backsplash Layout Help stradt03 Tiling, ceramics, marble 9 03-10-2012 09:10 AM
Yikes! old house, old kitchen tile backsplash LLJean Tiling, ceramics, marble 1 03-19-2011 01:57 AM
Kitchen tile backsplash?? momof2labs Tiling, ceramics, marble 3 02-24-2010 06:29 AM
Replace kitchen tile without moving cabinets and countertop stubits Tiling, ceramics, marble 7 02-18-2010 10:56 AM
Laying diagonal tile on first floor - unsure of how to meet up the tile HRS1 Flooring 9 08-22-2009 03:50 PM
