Toilet Flange - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 03:21 PM   #1
toilet flange
We just replaced the tile in the bathroom - should the flange sit on top of the new tile or be recessed and flush with the top of the new tile?
blackcats is offline   Reply With Quote
Old 08-07-2011, 04:36 PM   #2
Rewards Points: 79
It should sit flush with the top of the tile with the tile cut to fit around it. This will give the best seal for the toilet and also give your toilet more stability
Dwillems is offline   Reply With Quote
Old 08-08-2011, 07:20 AM   #3
Rewards Points: 5,336
Normally the flange sits on the tile. When the flange is lower, you can buy a spacer kit that will raise the flange up to it's proper height.
The problem with a lower flange is the seal. A standard wax ring will not reach both surfaces and seal the connection. This allows water and sewer gas to leak out.
They do sell oversized wax rings, but I like to use the spacer kits as it keeps the space close to the original.
I take it you kept the original flange because it was a lead one?
Ron
B. Franklin 1759
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Toilet flange questions AngeloUCF Plumbing 16 03-09-2011 08:39 PM
tile and toilet flange benshouse Plumbing 3 12-29-2010 06:02 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 05:37 PM
