Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 04-06-2011, 12:56 PM   #1
Tiling a Tub Surround
I've remodeled the bathroom and I'm installing new tile and have a single water control valve. What do you do to seal around the single water control The valve cartridge is what extends through the opening.
Paul the dyi'r is offline   Reply With Quote
Old 04-06-2011, 01:35 PM   #2
Not so new
12penny's Avatar
...should be a trim ring goes over the valve. About 7" in diameter. It has a seal on the back of it.
12penny is offline   Reply With Quote
Old 04-06-2011, 02:12 PM   #3
Thumbs up
There is trim that goes over it, however, I didn't know if it was necessary to seal off the wall opening other than with the trim.
Old 04-06-2011, 06:47 PM   #4
Over time the seal will dry out. To keep it sealed, I run a small bead of clear caulk around the perimeter of the plate. If you visualize the plate as a clock face, I run it from 7 0'clock around to 5 o'clock leaving the bottom open for drainage.
Ron
repair tiling and tub surround Commops106 Building & Construction 0 04-05-2011 08:11 PM
Tiling Bath Surround vleach Interior Decorating 1 10-26-2010 06:23 PM
Tiling Shower Surround bwad Remodeling 0 08-29-2010 06:54 PM
Tiling stub surround -- my detailed plan 99miles Remodeling 1 08-17-2009 05:55 PM
Fireplace surround tiling Ducowti General Discussion 8 10-28-2008 10:16 AM
