Tiling Showers - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-11-2013, 08:26 PM   #1
tiling showers
How long should it take an experienced tiler to tile a 3 sided shower- fairly straightforward walls, no window, etc.
dianepm is offline   Reply With Quote
Old 09-11-2013, 09:05 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,836
Assuming the walls are ready.....no prep work....I'm a DIY guy and it would take me about a day...but then again, I would also have a couple of beers along the way....
If your asking because the person is getting paid by the hour....don't use that person....it should be by the job.....if your asking because you need to plan around it....then...yea, about a day.
With that said....if the walls are not perfect....all bets are off.....it's like painting...the actual painting does not take long....a majority of the work is the prep......and the prep is what determines a good paint job or bad paint job.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
fast eddie 411 (10-03-2013)
Old 09-11-2013, 09:09 PM   #3
DIY staff
Rewards Points: 7,174
Usually a day to tile--perhaps two if there is a border or a niche--another half day to grout---add another if there is a floor to tile---
Old 09-11-2013, 09:17 PM   #4
cannot figure out how to continue the dialogue in a thread on this
Old 09-11-2013, 09:18 PM   #5
They are doing many things and charge by the hour....however, the first week they went like gangbusters. Now i see little progress
Old 09-12-2013, 06:43 AM   #6
DIY staff
You see why hourly charges are not good on a standard project.
Your description of the work must have been missing some of the scope of the work--
Did the job include demolishing an old shower? Adding new framing? Updating the plumbing? Adding a new shower pan? Durrock and waterproofing the walls?
Let us know a bit more about the actual work----
Old 09-12-2013, 09:56 AM   #7
I am speaking specifically about the amount of tiling. The prep work/ backer board was done. Part of each of two shower walls were done in two days with a contrasting tile row on each if those walls. I did not mention other tasks as the only thing done those days was that much. To me that seems like a few hours for each of two walls for 1 guy. I am preparing to see how many hours they charge me for.
I know that there are several components and steps, but I am trying to determine how many hours just that piece if the project should take an experienced tiler. In the two days I though each shower, one a surround of a standard size bathtub, and one a small 3 sided square shower stall. The plumbing was not worked on on these days. I thought they would be tiled and ready to grout on the next work day.
Thanks for your help!
Old 09-12-2013, 10:05 AM   #8
DIY staff
We do them quickly---one day for tile--two if there is a niche or accent stripe of mosaic---then 1/2 day to grout----return to caulk and get the pay check---
I seldom work by the hour----usually by the job.
Old 09-12-2013, 10:10 AM   #9
Too bad you're not in Pgh, Mike. Ty for your reply
The Following User Says Thank You to dianepm For This Useful Post:
oh'mike (09-12-2013)
Old 09-12-2013, 01:58 PM   #10
Rewards Points: 4,796
It depends a lot on the size of tile, type of tile, and accents, trim and niches. With 12" tile, you can fly. With glass it's quite tedious. With subway it's much slower than 12". With mosaic you can get very slowed down at certain points. For a simple shower, 1 day to tile and 1/2 day to grout. It could take 2 or 3 days to tile as it gets more difficult.
jeffnc is offline   Reply With Quote
Old 09-12-2013, 05:06 PM   #11
DIY staff
Jeff is right about glass or stone mosaic---by far the most difficult and frustrating of the tiles----rocks glued to a handkerchief-----tedious to install neatly.
OSB + Plywood = solid base for tiling? Denisrus Flooring 35 05-18-2012 11:13 PM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
