Tiling Painted Cement Walls ... HELP Please!!! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 09:07 PM   #1
Hey There, I have a 1950's cinder block house that I'm updating. In the bathroom I'm wanting to tile, but all the walls have a skim coat of cement over them, then about 7 layers of oil base paint. I was told by a tile PRO that I need to ruff up the paint so the adhesive would stick. Well ruffing up oil paint isn't that easy with all the layers of paint. It just gums up my wagner paint eater. So I started stripping the paint off one wall, inside the walk in shower stall. And boy was a mess I've got now, it's coming off but very time consuming. There's got to be a easier way!!
What would be the best way to prep these painted cement wall for tiling???? Do I need to remove all the paint first?? Would it be better to wrap the shower stall with 1/2 inch cement board and start with a fresh clean surface?? Any suggestion or comments would be great appreciated!
http://www.diychatroom.com/members/g...laster-job.jpg
gapeahen is offline   Reply With Quote
Old 08-26-2010, 03:01 AM   #2
Must remove ALL PAINT FRIST!
After reading older post I see that I must remove ALL PAINT first!
And not to use any paint strippers, as I've already done......Looks like this bathroom is going to take some hard work, time and make a big mess!
Old 08-27-2010, 05:41 AM   #3
I would agree that most of the paint needs to be removed, since it will likely loosen under the tile and cause problems later. But why can't you use strippers?? There are strippers that are safe to use indoors(but ventilation still a good idea).
Old 08-27-2010, 09:59 PM   #4
Rewards Points: 292
What about putting a backer board over the existing wall. Not sure the best way to attach but sure it can be done. Maybe furring strips fastened with tap con screws then nail or screw backer to furring strips, or maybe it can be directly attached to the walls.
Jim F is offline   Reply With Quote
Old 08-28-2010, 01:32 AM   #5
Rewards Points: 558
Just a quick question: did you check the paint for any lead content before you started removing it?
epson is offline   Reply With Quote
Old 08-28-2010, 08:04 AM   #6
adhere 1/4" cement board over existing walls is the recommended route.
gjjr2001 is offline   Reply With Quote
Old 09-01-2010, 11:56 PM   #7
1/4 Cement Brd & Hiding Ugly Pipes
yes, that would be the easy way for sure. What type of screws should be use on concrete wall?
There another issue about the water lines coming up from the floor. Can a wall be built around these pipes to hide all the ugly. If so what the best way to tackle it? Build a frame and cover with cement board?
Haven't check for lead yet. Was told as long as the paint wasn't in dust form wasn't harmful unless I was to eat it!! lol! But yes a lead test is important! If sand blasting is used in removal of all this paint I will be doing a lead test first. Thanks for the reminder!
http://www.diychatroom.com/members/g...needs-help.jpg
Please view my album for my work in progress!
Old 09-02-2010, 01:49 AM   #8
Images of my bathroom mess!
Tiling Painted Cement Walls ... HELP Please!!!-bathrm1.jpg   Tiling Painted Cement Walls ... HELP Please!!!-shwer1.jpg   Tiling Painted Cement Walls ... HELP Please!!!-shw_pipes1.jpg
Tags
cinder block wall , painted cinder block wall , tiling shower walls
Tiling over greenboard outside shower area toocheaptohire Remodeling 4 04-10-2009 08:42 AM
Washing flat painted walls n0c7 Painting 6 10-02-2008 03:43 PM
Tiling a porch over a painted concrete surface Harls Building & Construction 1 07-14-2008 07:34 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 02:50 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
