Tiling - How Difficult To Remove From A Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-18-2008, 09:52 AM   #1
Send a message via AIM to popiesbaby
tiling - How difficult to remove from a wall?
Hey guys how had is it to remove ceramic tile from a wall without tearing out the wall?
popiesbaby is offline   Reply With Quote
Old 12-19-2008, 12:57 AM   #2
General Contractor
If it's over drywall, the best solution is to just tear it out and install new drywall. It's not worth the hassle to do otherwise.
If it's set on a motor bed, we've been able to use a flat chisel behind the tiles to pop them off. then a little scraping to clean up the surface and you can install your new tile.
jensenconstruction is offline   Reply With Quote
Old 12-19-2008, 10:17 AM   #3
bradnailer's Avatar
If the tile has been glued directly to drywall, when you try to take the tile off, you'll generally pull the paper off the drywall. So, as was mentioned, it's generally faster and cleaner just to take down the drywall.
bradnailer is offline   Reply With Quote
Old 12-19-2008, 11:46 AM   #4
K&B Remodeler/Tile Guy
angus242's Avatar
I agree with both statements above
Angus
My Albums
angus242 is offline   Reply With Quote
How do you remove wall board glue? Heidi_Mp General DIY Discussions 4 10-16-2008 09:09 PM
Remove part of load bearing wall billyg Carpentry 2 02-25-2008 12:20 AM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
