Tiling - Difference In Thickness. Glass Tile Vs Porcelain - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 02:16 PM   #1
tiling - difference in thickness. glass tile vs porcelain
I'm just about ready to tile my shower, but i have a small problem. My porcelain tile is about 1/4" thick and the glass accent tile is only about 1/8" thick. any suggestions on how to make up the difference in thickness?
jbitt is offline   Reply With Quote
Old 06-11-2010, 07:17 PM   #2
DIY staff
Rewards Points: 7,174
I use strips of thin white plastic--FRP board to be exact--One the the "pros" will undoubtably have an opinion on that!
It works for me.--Mike--
Old 06-13-2010, 02:22 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
None of the thinsets used today are recommended for use with plastic anything. They won't reliably stick to plastic. So...not the best idea!
You can comb a little thinset on the back of the glass and let it dry. Then sand it off to the needed thickness. You can apply some thinset to the wall and let it dry, then sand it off to the desired thickness. Glass tiles may require special thinsets and that information should come from the glass tile maker.
There are other ways to accomplish this also but you wouldn't readily have access to the products to do it with.
XXX
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 09:54 PM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 08:33 AM
Glass shower enclosure- What thickness should I use? showerneeded Remodeling 2 06-05-2007 07:28 AM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
