Tiling Around Tub With Very Wide Flange - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 10:07 AM   #1
Tiling around tub with very wide flange
The installation instructions for our whirlpool tub show the backerboard coming down in front of the flange, and the flange being flush up against something above it. The problem is, the flange is almost 1/2" thick. In the diagram it shows it being flat.
So my question is this: Do I need to fir (?sp) the studs out further to make it overlap, or do I have it mount flush on top of the flange?
Here's the picture from the installation instructions:
http://i27.photobucket.com/albums/c1...gemounting.jpg I don't know how to get it to show in the actual post.
You'll see a dark gray line behind the concrete board that is flush above the flange. But it doesn't tell me what this is. I thought it might be the plastic sheeting, but that doesn't make sense because that's barely any thickness and the flange is almost 1/2" thick.
You can't see the flange really clearly, but this is the tub we have:
http://www.americanstandard-us.com/p...l.aspx?id=1742
Looking at the "images" tab it shows one installed and the flange is showing on the long side, but not on the narrow side. That's completely different from their installation instructions.
Any suggestions?
petsparkle is offline   Reply With Quote
Old 04-20-2009, 03:12 PM   #2
I would fir out the studs so the CBU comes out and down over the lip to within 1/8 to 1/4" of the tub deck.
R&D Tile is offline   Reply With Quote
Old 04-20-2009, 03:17 PM   #3
Unfortunately, we've got it hung now and it's sitting on top of the flange. Is there anything else I should do, or do I need to take it down and fir out further? If I need to fir more, can I just put extra firring strips on top of each other to get the depth? I'd probably need to go 3-4 deep to get it out far enough.
I also have a duck liner that my husband installed to the studs and this is supposed to be flush with the CBU and a bead of silicone goes around it where it connects to the CBU. It's impossible to remove without destroying it. I don't want to spend another $50 on one of these if I can help it. Is there a trick to getting it out? Any way I can do this differently so I don't have to remove it?
Old 04-20-2009, 03:53 PM   #4
In case anyone else is having this issue, I just talked to American Standard. The CBU can go flush to the flange or come over it, but it must be 1/8 up from the tub deck if you choose to go over it. I'm glad they called me back!
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 05:51 PM
cast iron flange Jrebhun Plumbing 2 09-06-2008 12:45 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
Toilet Flange and Flooring brneilly Remodeling 4 04-20-2008 11:37 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
