Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 02-09-2010, 04:11 AM   #1
Tiled Shower Surround Help
Hello,
I have, what I perceive to be, a big mess. Here is my situation. I've recently torn out an old one piece fiberglass tub and surround. I've installed a new tub and I am prepping to install a porcelain tiled surround. I've installed all of the Hardiebacker without any major problems, but then I made a stupid mistake while prepping the transitional seams from Hardie to drywall. You see, I am not taking the surround all the way to the ceiling, so the Hardiebacker will be meeting up with drywall along all the top edges and two side edges. All of the drywall is pre-existing drywall that has been painted except one spot above the surround where I had to install a piece a green board. I haven't taped or applied thinset to any of the interior Hardiebacker seams, but I was stupid and applied tape and joint compound to the seems between the drywall and Hardiebacker. I read that I should not have used joint compound on these seams, so I attempted to remove the joint compound so I could redo the seams using thinset. My attempt at removing the joint compound is failing miserably and I'm afraid I'm screwing everything up. There are spots along the edge of the green board (where it meets the Hardiebacker) where the the green paper was peeled off when some of the joint compound was removed. It is probably important to know that I plan on having the tile overlap each of the Hardie/drywall seems by less than an inch. Here are my questions:
1) What is the most logical way to remove the joint compound? Some areas have as much as 1/8" thick to make a smooth transition from the Hardiebacker to the drywall.
2) What can I do to remove the joint compound from the green board w/o further damaging it?
3) What can I do about the spots of the green board where the green paper facing has been peeled away? This is a major concern as it is along the seam above the surround where the Hardiebacker and greenboard meet. Will priming and painting the greenboard before applying thinset help make those "bare" spots a bit more moisture resistant?
Sorry for the long post, but any and all help will be greatly appreciated. Thank you!
Tiled Shower Surround Help-greenboard-damage.jpg   Tiled Shower Surround Help-greenboard-mess.jpg   Tiled Shower Surround Help-right-wall-mess.jpg   Tiled Shower Surround Help-left-wall-mess.jpg
CluelessNewbie is offline   Reply With Quote
Old 02-09-2010, 08:23 AM   #2
Remodeling Contractor
1) & 2) remove it with a scraper and then sand paper
3) Repair with a skim coat of Durabond 90. This will not attract the mold like the compound in a bucket.
But... you should not be using green sheetrock any more. This was a failed experiement and has proven to not work in resisting moisture.
Old 02-09-2010, 08:51 AM   #3
Judging by the level of projects that you're doing, you should own a decent shop vac. Get yourself a random orbital sander that will attach to the vac hose, slap on some coarse grit paper, and go to town.
No big deal, you didn't make a huge mistake.
Dairylander is offline   Reply With Quote
Old 02-09-2010, 11:36 PM   #4
If it's regular premixed in a bucket or box, wipe it off with a wet rag.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
Old 02-10-2010, 10:33 AM   #5
Tileguy
Bud Cline's Avatar
Leave well enough alone, don't waste your time trying to remove the joint compound. Simply use a liquid waterproofing to paint over the compound a few times and seal it. Not the best approach but none the less a workable solution. Be sure to use a quality paint when you paint the walls so as to keep the moisture out of the walls.
SIDE NOTE: If you wet the joint compound it will scrape out easily.
Tags
drywall, joint compound, shower, thinset, tile
Bathroom shower surround StevePax General Discussion 0 11-12-2009 01:31 PM
New tiled shower won't drain; mortar in drain. catitudes Plumbing 5 03-29-2009 02:08 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
Attach Shower Surround to Studs on Outside wall? BillyDIY Plumbing 2 08-25-2008 02:09 PM
Tub surround shower door issues Zharkov Plumbing 14 06-30-2008 11:52 PM
