Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 06-21-2011, 11:29 AM   #1
tile work
My contractor butted up the corners in the shower is that right or do I have to rip the wall out and retile. Very hard to grout with no corner space . I can only caulk it .
oceandweler is offline   Reply With Quote
Old 06-21-2011, 11:33 AM   #2
NACE Coating Inspector
mustangmike3789's Avatar
tile work
yes you should caulk it, grout will not stay in a corner too long.
mustangmike3789 is offline   Reply With Quote
Old 06-21-2011, 11:43 AM   #3
tile work
Should there have been a 1/16 gap at the corner or butted up tile is correctly installed
Old 06-21-2011, 12:03 PM   #4
tile work
yes there should be a small gap to accept caulk and for movement. good possibility of tiles cracking in the future if it is too tight.
Old 06-21-2011, 12:27 PM   #5
tile work
I may have to replace the wall some look tight
Old 06-21-2011, 12:37 PM   #6
tile work
Should I leave it and hope for the best
Old 06-21-2011, 01:03 PM   #7
sdsester's Avatar
tile work
You shouldn't have to redo the whole wall. You can always cut a relief space in with a mini or roto tool and mini masonry disc bit thing if you are panicked.
sdsester is online now   Reply With Quote
Old 06-21-2011, 01:55 PM   #8
tile work
Thanks for your input appreciated
Old 06-21-2011, 07:06 PM   #9
Tileguy
Bud Cline's Avatar
tile work
Leave it alone for now it may be just fine. Other than that I would agree with Mike 100%. Caulk it and forget it.
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 10:07 PM
Tile over, or tile under? jeffyisfive Flooring 4 01-24-2007 12:29 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
