#1 |
Tile shower surround meeting sheetrock on wall?
Hi everybody,
We are (probably) going to tile a shower surround which has two full walls and one partial wall (5' above the tub with a free standing ledge and a gap to the ceiling). There is melamine on all three sides, going to the top of the partial wall and most of the way up the two full walls. We want to take the melamine down, cut the probably soggy sheetrock out, put up hardiboard, and tile up to where the melamine stops now (about 2 feet down from the ceiling). This approach would leave about 2 feet of painted sheetrock between the top of the tile and the ceiling. I am assuming we would replace the sheetrock up to the ceiling and repaint the whole bathroom. Does anyone have advice on how to handle where the tile would meet the sheetrock? Should we put up lipped bullnose, or is there some special trick? We think we will use flat bullnose at the top of the partial wall. The house was built in 1950 if it matters. Sorry I don't have any pictures, but I will work on it later. |
#2 |
Super Moderator
Terminating the tile work with bullnose is the standard way--I'd suggest that route--Mike---
New members: Adding your location to your profile helps in many ways.--M-- |
#3 |
I guess I know that bullnose is the accepted transition, my question was what to do if the hardiboard is not flush with the sheetrock.
Then the question is should I do whatever I have to to make it flush, or is there a tile solution if not. Tx! |
#4 |
The sheet rock and the tile board are both 1/2" thick so it should come out flat.
Just tile up high enough so it covers over the gap between the tile sheetrock and tile board. |
| Display Modes | |
| Shower install on outside double wall construction | boerssd | Plumbing | 0 | 01-16-2012 02:02 PM |
| Shower pan/ tile problem | Pawl | Tiling, ceramics, marble | 8 | 01-16-2012 10:32 AM |
| Gap between bathtub surround and sheetrock on wall | Beerad77 | Building & Construction | 3 | 01-03-2012 12:24 AM |
| need to waterproof over CBU under shower wall tile??? | frgwtchr | Flooring | 6 | 08-20-2009 09:39 PM |
| Tile Baseboard on outside of plastic shower pan at linoleum joint? | GaryS | Tiling, ceramics, marble | 2 | 07-26-2009 01:39 PM |
