Tile Shower Pan Leak. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-22-2012, 05:19 PM   #1
Tile shower pan leak.
Hello everyone. I'm new to the site and would like to ask a question. I have a slab house with a tile shower and the pan is leaking. Is there something I can paint,spray or roll on the tile so the water won't get to the pan? I'm gonna remodel the bathroom later but can't right now. Thanks for all your help.
Big jake is offline   Reply With Quote
Old 03-22-2012, 06:22 PM   #2
You can try applying a sealer to the tiles but that will probably only slow it down for a couple months. To get a better understanding of how a tile shower pan works check out this article.
hotmopshowerpan is offline   Reply With Quote
Old 03-22-2012, 06:24 PM   #3
Rewards Points: 14,312
Not going to happen. Why not just regout and seal it?
Since we have no picture to go by so guesses as to why it's leaking, seal under the drain is leaking, someone used grout and not caulking where the tiles and walls meet.
Old 03-22-2012, 06:53 PM   #4
So your saying scrape all the grout out and replace it then seal it? There is come cracks in the grout but I didn't thing that matters since there is a pan.
Old 03-22-2012, 07:01 PM   #5
What do you think was stopping the water from getting to the pan and causing the pan to leak.
Old 03-22-2012, 07:06 PM   #6
I had no idea, but now I know. So how does water make the pan leak?
Old 03-22-2012, 07:15 PM   #7
DIY staff
Rewards Points: 7,174
Tile and grout are not a waterproof surface----the pan itself must be waterproofed--under the tile/
I need to know what kind of pan you have and the type of drain---
It might be possible to remove the tile and apply a surface membrane like Hydroban,as a temporary fix.
I doubt it but it might work---if it the pan that is leaking and not the pan/wall junction---
More details----Sounds like you need to rip the pan out and the walls (or part of the walls--)--Mike----
Old 03-22-2012, 07:29 PM   #8
Not sure what the pan material is made of. The house was built in 91, it has a PVC drain if that helps. I'm gonna update the bathroom in November so want to spend a arm and leg right now.
Old 03-22-2012, 07:40 PM   #9
Will that hydroban stick to the tile? I'm thinking rhino liner or some other type of bed liner might fix it for now.
Old 03-23-2012, 05:12 AM   #10
DIY staff
Yep--it'll stick--but it need to be covered as it is to soft for a wear surface.
Crack in old shower tile Jeff DIY Flooring 21 01-15-2012 02:11 PM
Repairing ceramic tile shower jimmyj Building & Construction 1 04-25-2011 08:09 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Delta scald guard shower valve leak pdamania Plumbing 1 03-08-2011 05:45 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 12:27 PM
