Tile To Outside Corner - Cleaning Up Edge - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 09:11 AM   #1
RDS
Rewards Points: 150
Tile to outside corner - cleaning up edge
When you're tiling to an outside corner -- with the tile ending at the corner, i.e. not wrapping around -- how do you deal with the fact that, when you're facing the non-tiled wall, i.e. seeing the tile edge-on, you can see the layer of thinset behind it? Looks kinda ugly. How do you clean up that edge? Latex caulk? Joint compound feathered out onto the adjacent wall? I'm considering both approaches, but just wondering what the pros do. Thanks.
RDS is offline   Reply With Quote
Old 06-04-2009, 06:18 AM   #2
Bull nose tile, has a rounded edge that blends into the corner.
Old 06-04-2009, 07:46 AM   #3
RDS
Rewards Points: 150
Thanks. We're using bullnose, but it still has thinset behind it, no? Thinset that's still visible? Maybe I'm doing it wrong. I'll figure it out. Thanks again.
Old 06-04-2009, 12:52 PM   #4
Registered User
Rewards Points: 5,498
As just Bill said, and maybe read here:
http://books.google.com/books?id=D5F...+tile#PPA20,M1
Be safe, G
Old 06-04-2009, 05:05 PM   #5
RDS
Rewards Points: 150
Thanks for that link. Maybe I'm being dense or unclear. Here are pictures to (hopefully) clarify. First pic shows the surface bullnose, with the one rounded edge of the tile right at the outside corner. Second pic shows what you see when looking at the same corner from a couple of steps to the left -- the rounded edge but also the thinset behind it. Just wondering how to hide that.
(For sake of honesty I can't claim credit for the tile work, which looks great aside from this little issue.)
Sorry if this is dumb -- maybe there's an obvious solution I'm missing, or this is one of these things people just live with.
Tile to outside corner - cleaning up edge-img_0840.jpg   Tile to outside corner - cleaning up edge-img_0841.jpg
Old 06-05-2009, 09:47 AM   #6
LeviDIY's Avatar
Rewards Points: 252
RDS - In my bathroom, I had the same issue... did the walls/tiling myself, and figured some white caulk would be fine... doesn't look THE BEST, but I'm OK with it... curious if there are other creative solutions.
LeviDIY is offline   Reply With Quote
Old 06-06-2009, 06:30 AM   #7
Caulk works well. Siliconized latex it it will be painted.
Old 11-23-2014, 12:09 PM   #8
Rewards Points: 2
I installed drywall corner bead to the outside corner before tiling.
homiha is offline   Reply With Quote
Old 11-23-2014, 12:49 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Clean out that groove so that it will accept caulk evenly all along its length and then use a siliconized caulk to fill the crack, Dress it off with a damp sponge and you'll be fine.
XXX
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Slate Tile Roof Cleaning Tampa Florida - Slate Roof Cleaning Using Lift. apple roof cleaning Roofing/Siding 1 12-31-2008 10:01 AM
Old tub needs new tile. Need advice on edge of tub. skits Remodeling 1 12-13-2008 03:30 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
