Tile Issues In Bathroom Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 12:07 PM   #1
Tile issues in bathroom shower
I had my bathroom completely remodeled last year. I decided to add mosaic slate tile in the shower/ jucuzzi area. The problem with this tile is it appears to be rusting in areas where water hits it when the shower is turned on.As you can see in the pick there is an area of rust where water continuously hits that specific area. What can I do to alleviate this problem?
Keith vent is offline   Reply With Quote
Old 04-14-2012, 12:39 PM   #2
Pure Genius
Rewards Points: 150
Did you seal your tile? Have you tried scrubbing your tile? Is your water rusty?
Dierte is offline   Reply With Quote
Old 04-14-2012, 01:07 PM   #3
Rewards Points: 12,886
Hard to say from that dark picture, but is the staining localized to certin tiles or all over the area?
If it's all over then you need to get your water tested and may have to add a water softner.
Old 04-14-2012, 08:42 PM   #4
DIY staff
Rewards Points: 7,174
That is Chineese slate.I bet---it is loaded with iron---poor quality stone---bad choice in a wet area.
It will continue to rust until it runs out of iron---sorry---live with it or remove the slate and retile---Mike---
Old 04-15-2012, 10:15 AM   #5
Yes i did seal the tile. I have city water as well, its not hard water
Old 04-15-2012, 11:46 AM   #6
www.No-Curb.com
JohnFRWhipple's Avatar
We always recommend our clients soak their tile first and the dry. You may only have one piece rusting there and it should be removed.
If you get a coring drill bit and carefully drill into the tile about 80% you will be able to pop the bad tile out.
Did you waterproof behind the slate tile?
JW
JohnFRWhipple is offline   Reply With Quote
Old 04-15-2012, 04:09 PM   #7
JW
I dont know, had the bathroom done professionally
Old 04-25-2012, 09:41 AM   #8
www.No-Curb.com
I've seen professional nail on Hardi Board with common 2" nails.
I've seen Pro's do it with a framing gun (nail up backer board)
It could be that a common nail is rusting out from behind that spot or that one of those 2" tiles has a heavy iron content. My money is on the second one from the top.
Too bad. It's a sharp looking install.
JW
shower tile/floor tile in bathroom sabush0511 Flooring 1 06-05-2011 07:07 PM
Tile Shower Remodel Questions roybfr Kitchen & Bath Remodeling 1 07-31-2010 03:43 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Any issues with putting Allure flooring over a bathroom tile foor? BIGDOG2513 Flooring 1 03-05-2009 02:59 PM
Tile in Shower and on Wall of Bathroom jwhiteuwc General DIY Discussions 2 02-02-2009 09:21 PM
