Tile Counter Waterproofing Options - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 02:44 PM   #1
Rewards Points: 45
I'm currently in the middle of building countertops for my new kitchen cabinets in preparation for 12" x 12" porcelain tiles. I currently have 3/4" and 1/2" plywood sheets glued and screwed together and fastened to the cabinets as the base for the countertops. Unfortunately I didn't do enough research beforehand and bought regular plywood as the substrate instead of exterior grade. I was initially just going to apply Ultraflex 2 tile mortar directly to the plywood and then stick on the tiles. I figured that if all the grout lines were sealed correctly and regularly maintained that water intrusion would not be an issue. I assumed this because my parents recently changed their kitchen counter tops from 6" white gloss tiles to slab granite and when my dad pulled off the old tile and mortar himself (to save on labor cost) we noticed that it was just regular plywood underneath. Their house is ten years old and there were no signs of water intrusion.
Anyway, it seems that after some research this won't be acceptable (especially around the sink). I'm leaning towards using this Schluter Ditra sheet membrane that I've been reading about. Will this work with the thinset that I purchased? Another option is cement backer board but I'd rather stay away from this since it will be harder to install not mention raise the height of my counter tops and cause issues with my edge molding. Also, is there any paintable liquid membrane that I can apply to the plywood to seal it prior to applying the thinset?
Matt
Lafayette, LA
GeauxCajuns82 is offline   Reply With Quote
Old 08-01-2010, 05:13 PM   #2
DIY staff
Rewards Points: 7,174
There are two paint on membranes that should work---Redguard--Home Depot--$45- a gallon
And HydroBan by Latacrete--$110-a gallon
The Redguard sounds like the ticket--pay extra attention around the sink and the underside around the sink.
I always put 1/4 inch backer board on a counter,however if you waterproof,I think you are good.--Mike--
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Raised tub - waterproofing solutions for wood frame against granite tile? lazzlazz Tiling, ceramics, marble 4 05-23-2010 01:15 PM
Tile Backsplash - On Top or Behind Counter? Shandon Remodeling 10 06-10-2008 08:09 AM
Granite tile counter question ryguy Flooring 3 09-27-2007 11:31 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
