Tile Bath Tub Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 11:32 AM   #1
tile bath tub wall
Does drywall/blueboard need to be flush with the glazed cast iron tub before the wall tiles are mounted? or should there be a small gap?
Ginarain is offline   Reply With Quote
Old 03-12-2012, 11:44 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Depends.... are these also shower walls?
12penny is offline   Reply With Quote
Old 03-12-2012, 11:59 AM   #3
Rewards Points: 528
You should not use drywall or blue board near the tub. yes there should be a gap.
framer52 is offline   Reply With Quote
Old 03-14-2012, 06:28 PM   #4
How much of a gap, and how do you tile over the gap?
tracysnow is offline   Reply With Quote
Old 03-14-2012, 08:21 PM   #5
DIY staff
Rewards Points: 7,174
The cement backer board is brought down to the top of the tub flange---that gap is filled with thinset as the tile is installed---
If the CEMENT board is to receive a surface water proofing like Red Guard or Hydroban--the seams and that gap are filled before coating---use tilers mesh in the corners and open seams--
Do not use green board or blue board---not approved under code in the US--to many failures---there are exceptions.
unlevel floor and diff. thickness wall tile bryan1282 Tiling, ceramics, marble 2 08-08-2011 10:26 AM
Full wall of tile over drywall eend Drywall & Plaster 1 07-24-2011 06:30 AM
Putting wall ceramic tile over wall ceramic tile in bathroom shower Dottie43 Kitchen & Bath Remodeling 1 07-14-2011 12:38 PM
Wall tile - five questions CZ DIY Tiling, ceramics, marble 4 04-24-2010 02:44 PM
Replacing drywall without removing tile through an interior wall MLP Drywall & Plaster 6 08-06-2009 12:35 PM
