Tile On Acrylic Bath - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 11:35 AM   #1
I am looking to freshen up our master bathroom now, while trying to keep it cheap. We have a big white Arrow Acrylic Bath that unfortunately takes up way to much room in the bathroom.
Is it possible to put tile on all the sides and flatwork? If so what is the best process to do it.
Thanks.
The bath looks like this:
BOHICA is offline   Reply With Quote
Old 01-08-2009, 12:09 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Can't really tell from the picture but is that a fiberglass-like surround (felxible) or a solid surface (like Corian) one?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-08-2009, 01:19 PM   #3
It is pretty cheap, so I'm going with some sort of fiberglass-esque material. It definitely isnt solid.
Here is a link to the exact type of tub we have.
http://www.luxurybathsbyarrow.com/pr...bs_acrylic.cfm
Old 01-08-2009, 01:21 PM   #4
angus242's Avatar
That's a big no to tiling. You need a very solid base/substructure to tile.
Most tile is installed over a base of cement backer board.
Angus
My Albums
Old 01-08-2009, 01:32 PM   #5
Thats what I thought, but I was hoping it could be pulled off to help add some color in that whole area.
Old 01-08-2009, 02:14 PM   #6
bradnailer's Avatar
It looks like you can remove all the siding because there appears to be caulk lines between the siding and the tub. But, to do it right, you'd need to pull all of the old stuff down and install a good foundation before you tile. It is do-able, but would be a chore.
bradnailer is offline   Reply With Quote
Old 01-09-2009, 08:05 AM   #7
Got home from work last night and decided to check it out more indepth. It is not fiberglass and is very much corian. Solid all the way to the drywall. Does that change anything or is it still a no go?
Old 01-09-2009, 08:58 AM   #8
bradnailer's Avatar
That possibly makes it easier to remove. Once you get it off, you can install cement backer board on the drywall then tile.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Cast iron vs. acrylic bath tub steve65 General DIY Discussions 17 11-08-2009 04:58 PM
Bath Tile Job tate16t Flooring 16 07-13-2008 08:56 PM
Tile Bath Tub? mommaroot2004 Remodeling 3 11-28-2006 08:28 PM
