Three Questions About Acrylic Tub Flange - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 08:26 AM   #1
Three questions about acrylic tub flange
I am in the process of installing a new acrylic tub with a flange.
I will use kerdi membrane to waterproof the walls. My drywall comes up to the top of the flange. A few questions:
  1. The 1/8" gap between the drywall and the top of the flange, should this be filled with mud, caulking, or mortar?
    1. My floor and floor supports don't squeak, and I am concerned about squeaking occurring if I just go from drywall to flange with a solid material like mud or mortar, but I am also not sure about mortar or mud bonding well with the caulking.
  2. The tub flange is pretty level with the drywall on the two short sides, probably only off 1/8". Do I just go over the flange with thinset, or should I mud and tape this first?
  3. On the long side, the drywall hangs over the tub flange by about 5/16". Is this overhang too much to fill with either the mud or the thinset? If I had to I could probably get behind the tub and shim it a 1/4". It would be a pain, but if it's worth it in the long run to prevent leaks or something, then I would rather deal with this now.
I'd greatly appreciate if you can answer one or more of these questions!
will83 is offline   Reply With Quote
Re-cementing around Toilet Flange & Flange installation for Tiling Floor crayola110 Plumbing 7 09-22-2012 12:02 AM
en Flange bolt. Not sure how to proceed. latenight Plumbing 4 08-07-2012 05:01 PM
Tiling around tub with very wide flange petsparkle Kitchen & Bath Remodeling 3 04-20-2009 03:53 PM
Toilet flange arrangement with new floor bvsmitty Plumbing 2 01-16-2009 05:51 PM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
