Is There Anyone That Will Just Change The Metal Frames In My Shower Surround? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 01:04 AM   #1
Question
Is there anyone that will just change the metal frames in my shower surround?
I have 2 bathrooms that have bright brass finishes that I want to update. The shower surround in each would be quite expensive to replace -- especially when the only thing I want to change is the finish (to a satin nickel) -- the master bath alone is comprised of 5 panels.
Does anyone know if there are companies that will just replace the shower surround metal framing and re-use my existing glass? I'm assuming that this would yield significant savings.
Thank you!
jonnybmcdonald is offline   Reply With Quote
Old 01-04-2011, 05:32 AM   #2
the Musigician
DangerMouse's Avatar
I would think what you propose would cost MORE! Have you considered painting the existing frames in a complimentary color?
WAY cheaper!
DM
Old 01-04-2011, 06:53 AM   #3
Next Time...New Build
Rewards Points: 150
DM is on the right track. Rustoleum has a lot of great products and finishes out now. I had a similar issue with a brass fireplace glass. I used the "hammered" finish by Rustoleum and it turned out great. Tape everything off and with about $15 you may get the look you are looking for.
RickyBobby is offline   Reply With Quote
Old 01-04-2011, 07:01 AM   #4
have a glass shop come out and give you a quote
The older I get the better I was
Old 01-04-2011, 08:10 PM   #5
I had thought about the Rustoleum products but figured it either wouldn't adhere well enough to the brass (I know I have to sand it down a bit first) and also wouldn't stand up to the punishment of a shower environment -- not just the wet and humidity but also the cleaning required. I may give it a try as a last resort -- especially if I decide to go with the alternative of replacing the glass panels if it doesn't work anyway.
Thanks all.
Old 01-07-2011, 11:23 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Thanks all.
I agree with you here. I seriously doubt it would last very long.
Old 01-07-2011, 12:04 PM   #7
Experienced
Jackofall1's Avatar
Search custom shower frames, and then contact them for more information.
Tags
frame , recycle , replace , shower , surround
Tiling Shower Surround bwad Remodeling 0 08-29-2010 05:54 PM
Using a tub surround for shower surround Sbruce Building & Construction 2 08-21-2010 07:21 AM
laminate floors and metal door frames homeimprovement Flooring 8 10-06-2008 12:47 PM
Insulating metal window frames SagittarianLady General DIY Discussions 6 12-08-2007 09:36 AM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 09:24 AM
