Tackling A Tub Replacement Myself...Help Me Out? - Kitchen & Bath Remodeling - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 04:47 PM   #31
Rewards Points: 219
Nope, no basement... House has a slab foundation
bassadict69 is offline   Reply With Quote
Old 12-30-2011, 04:57 PM   #32
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well for what it is worth...
I have fought way too many of those things over the years and I learned a long time ago not to keep frustrating myself with them.
I would take out the concrete patch, remove the existing fittings and be in a position to start anew when the time comes. I would think you would want to use anew overflow and drain kit anyway. You can install the waste and overflow, position the tub where it needs to be in relation to the walls and then rig-it-up through the access hole. Half the work will be done when the tub is in position. Any adjustment you will need comes at the end anyway when you attach the drain to the egress.
After everything is rigged and tested you can then fill-in the hole in the floor if you can't live with it being open.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
bassadict69 (12-30-2011)
Old 12-30-2011, 06:18 PM   #33
DIY staff
Rewards Points: 7,174
I agree---open slab--remove old drain set--add new P-trap---assemble drain set to tub and set tub drain attached (be sure to have nut and washer on drain set before lowering into hole)---
Old 12-30-2011, 07:04 PM   #34
Rewards Points: 219
Any advice for replacing the valve and shower head?
Old 12-30-2011, 07:14 PM   #35
DIY staff
You will need to learn to solder or find someone who already knows---
there may be a solderless method---but I am not the one for that---
Let's see what others have to suggest---Mike---
Old 12-30-2011, 10:43 PM   #36
Rewards Points: 219
Still looking for advice for replacing the 3 piece valve setup with a one piece... I am hoping to buy the stuff for that tomorrow.
Also, I have cleaned out around the drain and think I have it dug out down below where the drain screws onto the plumbing in the slab...I see no P trap.
Here are a couple of pics...
Old 12-30-2011, 10:52 PM   #37
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is there a trap down in the sand?
Go buy your new valve first. You'll need some fittings and a stick of copper if you intend to sweat the piping. Four or five male adapters, a drop ear, some elbows, a few connectors, you know stuff like that. It depends on what you have in mind.
Have you ever sweated copper before?
XXX
Old 12-30-2011, 11:03 PM   #38
Rewards Points: 219
No, never have! Was hoping to use shark bites to adapt the copper to pex or something along those lines.
I will dig down further tomorrow...after working last night then getting up today and working on this I am beat! Headed to bed...
Old 12-31-2011, 07:43 AM   #39
DIY staff
There is a P-trap right under that trap adapter--(threaded fitting)
Do you have your new tub on site yet? Check the measurements--old P-trap might be in the right place.
That happens so rarely that I assume a new one is needed ----
When you choose your tub mixer valve --let us know the brand and we will walk you through installing it---Delta--Moen--Kohler are the top three choices in my book--Avoid American Standard--big trouble getting parts when you need them.
Soldering is not that difficult---slip fittings like Shark bites are pricey and I am nervous about a fitting like that buried behind tile work--a failure would be expensive--heartbreaking,too.
Old 12-31-2011, 10:14 AM   #40
Rewards Points: 219
I do not have the tub yet, hoping to get it today along with the drain, valve and whatever else I need to do this.
We have dug a couple more inches and still found no P trap...does it really need to be replaced or can I simply change everything out above the threaded fitting?
Old 12-31-2011, 10:57 AM   #41
Rewards Points: 219
It looks like a drain coming from my sink which is on the other side of the wall, then the drain goes downward. I have stuck a clotheshanger into the dirt all around it and hit nothing.
Old 12-31-2011, 06:59 PM   #42
Rewards Points: 219
We made the trip to Lowes today and bought a tub and the fixtures for it. We dry fit the tub and it looks like the drain is about an inch off so I am hoping that will not be too big a problem.
Anyone know of any problems with using cpvc for the plumbing? The guy at Lowes really seemed to know everything about this tub installation and suggested sweating the copper...when I said I would rather not, his next suggestion was a shark bite fitting to adapt from the copper to cpvc. Besides fears of leaking shark bites, anyone know of any problems with doing this?
We also bought a Kohler toilet so we may be installing that this evening! Done that before!
Old 12-31-2011, 07:48 PM   #43
DIY staff
An inch off in what direction?
What type of drain set did you get?
I can't help on the shark bite stuff--no experience.
Old 12-31-2011, 07:59 PM   #44
Rewards Points: 219
Left to right or side to side not sure which way to call it.
Not sure of the brand since I am not home, but it is schedule 40 with button type plug
Old 01-06-2012, 04:50 PM   #45
Rewards Points: 219
I think we have decided to let a plumber hook up my tub drain and do the plumbing for the fixtures. He came out and quoted me 300 to do it. His references and BBB rating check out so I think we will take the easy way out on the plumbing then finish the bathroom ourselves.
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
replace replacement windows theone Windows and Doors 3 10-19-2011 09:16 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
