Support For Tub Apron - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 02:46 PM   #1
Rewards Points: 284
support for tub apron
My old tub apron sat directly on the slab. I was thinking of using a thin strip of linoleum as a cushion and moisture barrier. Unnecessary?
tns1 is offline   Reply With Quote
Old 09-27-2010, 11:40 AM   #2
Rewards Points: 284
I decided to get a cast iron, apron tub. My slab isn't exactly level and metal shims are suggested for the legs. With a level I can estimate and glue down some metal shims, but is this close enough? Considering the difficulty of moving the tub, and getting at the feet I want this to be a one shot placement. I am thinking it might be smart to add a thin shim of slightly compressible material like linoleum to all 4 legs. That way if any leg is 'heavy', it can squish down the material a bit. I assume I'll need to shim the apron too, but at least that is easily accessible.
Old 09-29-2010, 09:24 PM   #3
Rewards Points: 262
Yes they are heavy but it is possible and probably necessary to raise the tub and trial and error the metal shims under the feet. You can start with the first shim permanently placed under each foot then add and remove others if necessary. The apron can be supported temporarily of scrap 2x4's while you are placing the shims so the tub doesn't get dropped on your hands.
Jim F is offline   Reply With Quote
Old 09-29-2010, 09:27 PM   #4
Rewards Points: 262
On second thought, if the tub is resting on a concrete slab, it may not be necessary to have a shim under each foot. That is more to prevent the feet from sinking into a wood subfloor.
Old 09-30-2010, 12:12 PM   #5
Rewards Points: 284
What is supposed to keep this type of tub from moving around? With a steel tub you have nailing flange and a support stringer, but my instructions do not show the use of a support stringer around the perimeter. Do I shim it to prevent lateral movement?
Old 09-30-2010, 09:16 PM   #6
Rewards Points: 262
Your backer board should rest on that curved lip on three sides. That should hold it pretty well then the tiles layer on over that and follow the curve a little lower to about 1/8" abuve the horizontal surface then silicone caulk. What ever material you use under your finished floor be it backer board or wood underlayment should butt against the apron which will definately keep it from sliding out.
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
Best Method for attaching decking lateral support getzjd Building & Construction 2 05-19-2010 07:45 AM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Installation of gutter apron over existing apron dbosh Roofing/Siding 4 11-13-2009 10:44 AM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 06:07 PM
