Subfloor Levelling Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-13-2015, 02:05 PM   #1
Rewards Points: 77
Subfloor levelling question
Hi all,
I am remodeling my bathroom. There used to be a drop in type of tub as shown here:
I plan to put a regular tub and as a result I need to patch the large hole in the subfloor as shown here:
My existing subfloor is 1-1/8in plywood laid on top of 4x6 joists 4 feet in the center
I started patching the hole with 4x6 studs perpendicular to an existing floor joist as shown here:
However, when I layed the new plywood on top for dryfitting, I noticed that the new plywood thickness is slightly smaller... (less the 1/8th)
I was wondering if I could add stappled felt/tar paper along the new and existing joists to make up for the height difference (I don't think it would compress much).
The new plywood will be covered by the new tub and some tile (with 1/4in backerboard).
Any comment or other idea? (I 'd prefer avoiding SLC if possible)
Thank you for your help,
John
Slashp is offline   Reply With Quote
Old 02-15-2015, 06:46 PM   #2
RMK
Rewards Points: 16
If it is being covered with the tub I don't think you need to worry about it. If part of it shows in front of the tub tile mortar will cover it and allow you to level the floor. If you really want to fix it then I don't see any problem with the tar paper as you mentioned. However it is very thin. You could try drywall shims. They have been compressed when they were made so they should not compress any more. I have used them to level floor joist in a house I built. Another option and probably better would be thin plywood say 1/8.
RMK is offline   Reply With Quote
The Following User Says Thank You to RMK For This Useful Post:
Slashp (02-17-2015)
Old 02-16-2015, 05:59 PM   #3
Rewards Points: 22
In cases like this, I've occasionally used leveling compound with good success. It can be feathered paper-thin with a float if needed
southernboy is offline   Reply With Quote
The Following User Says Thank You to southernboy For This Useful Post:
Slashp (02-17-2015)
Old 02-17-2015, 11:35 AM   #4
Rewards Points: 77
Hi thank you for your message. Shouln't I be concerned with drywall shims that the cardboard might get wet and breaking up later since the tile might not be 100% waterproof?
John
Old 02-17-2015, 01:13 PM   #5
You will be able to stick an elephant in that tub.
One question,,, How long and wide is that area.?
ron45 is offline   Reply With Quote
Old 02-17-2015, 01:14 PM   #6
Rewards Points: 77
Better safe than sorry
Old 02-17-2015, 03:30 PM   #7
Rewards Points: 2,600
like Ardex. i would not shim with felt paper, it can compress over time.
concrete_joe is offline   Reply With Quote
Old 02-17-2015, 04:03 PM   #8
Rewards Points: 454
What kind of flooring are you going with? If its something with a motor bed just put it a little thicker next to the tub, if not use a floor leveler like somebody else suggested
scottktmrider is offline   Reply With Quote
Old 02-17-2015, 04:19 PM   #9
Rewards Points: 77
I will put tile (Plywood > thinset > hardibacker 1/4 in > thinset > 1/4 in tile)
and this bathtub:
http://www.us.kohler.com/us/Expanse%C2%AE+60%22+x+32-38%22+curved+alcove+bath+with+integral+tile+flange +and+left-hand+drain/productDetail/Soaking+Baths/427501.htm
The covered hole is 48 in wide while the tub at its largest is 38 in.
Concerning the bathtub installation, it has 4 legs and I am still debating whether I should set it on a mortar bed or on insulation foam (seems less messy)
John
Old 02-17-2015, 04:22 PM   #10
Rewards Points: 77
Hi,
What kind of shim would you recommand (I need around 1/8in) that would be incompressible?
I can't find plywood this thin at Lowes or Home Depot
John
Old 02-17-2015, 04:41 PM   #11
Rewards Points: 1,910
and this bathtub:
John
Long ago I had an acrylic tub with foam insulation under it instead of a mortar bed. I hated it. It squeeked and flexed. Maybe they do foam better nowadays but if I had to choose, I'd go with mortar.
The Following User Says Thank You to jogr For This Useful Post:
Slashp (02-17-2015)
Old 02-17-2015, 05:11 PM   #12
Rewards Points: 77
Thank you,
Any recommandation on the mortar I should use?
John
Old 02-18-2015, 12:37 AM   #13
Some tubs have their own reinforced bottom and doesn't require mortar, it basically lays flat.
On the link you posted it states 2 different methods, one mortar, and one has feet/base and requires adhesive.
The Following User Says Thank You to ron45 For This Useful Post:
Slashp (02-18-2015)
Old 02-18-2015, 08:27 AM   #14
if it comes with insulating pad, then a baseball size of insulating foam (maybe 1-2 of them) under the pad before setting tub, will keep things tight and quiet.
if you use mortar just get a thinset that is "flexible".
if it doesnt come with insulating pad then i would glue a piece of 1" rigid foam to tub, then set with spray foam or mortar.
if the tub has a pad and it sits about flush with floor, use spray foam, but use golf ball sized spots, etc.
wall ledgers support the tub, etc. the bottom is for insulating and quietness, etc.
The Following User Says Thank You to concrete_joe For This Useful Post:
Slashp (02-18-2015)
Old 02-19-2015, 06:58 PM   #15
Rewards Points: 77
Hi,
John
Any idea of what incompressible material I could use to make 3.5in x 4ft x 1/8th shims?
Regards,
John
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
