Sub Floor On Top Of Sub Floor - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 12:33 PM   #1
Sub floor on top of Sub Floor
I am remodeling our bathroom right now and as I have taken out a couple fo walls that were in there I have discovered that there is a sub floor on top of the orginal sub floor. The walls were nailed to the orginal sub floor and then the next layer was put in. Is there a purpose for this, or can this extra layer be pulled up?
farmallih1466 is offline   Reply With Quote
Old 01-16-2011, 12:37 PM   #2
Experienced
Jackofall1's Avatar
What kind of flooring was on there prior to the remodel, it is common to add a new sub-floor prior to installation of many flooring types. So to answer your question yes you can remove it.
Old 01-16-2011, 12:39 PM   #3
Done all of the time. if the toilet leaked and the original subfloor was bad....
framer53 is offline   Reply With Quote
Old 01-16-2011, 12:40 PM   #4
The flooring that was on this new sub floor on top was carpet. If I take that second layer off and put down a new sub floor if needed in place of the original sub floor that would be the best correct?
Old 01-19-2011, 05:07 AM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
What are you putting down in place of the carpet?
Old 01-19-2011, 06:04 AM   #6
We are going to be putting down tile. The floor on top is a particle board which I didn't mention before. I am going to take it out since it is a bathroom.
Old 01-21-2011, 09:56 AM   #7
Rewards Points: 5,336
Good move with the particle board!
If you're putting down tile, the 1 subfloor method will probably not be sufficient enough for the tile. The floor needs to be rigid enough to keep the structure from deflecting under load.
Ron
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
