Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 10-07-2012, 12:06 AM   #1
Stove in peninsula?
What are the considerations I should be thinking about for putting my stove and cooktop in a peninsula?
wwkayaker is offline   Reply With Quote
Old 10-07-2012, 02:15 AM   #2
Stove in peninsula?
over the top hood or down draft built into stove.
Kids knocking pans easily.
mae-ling is offline   Reply With Quote
Old 10-07-2012, 02:26 AM   #3
Stove in peninsula?
Wow the downdraft setup is not cheap. I don't want a hood as I have a mountain view I'm trying to open up. Back to the layout.
Old 10-07-2012, 06:32 AM   #4
Super Moderator
Stove in peninsula?
If you stick with the original idea-----Make sure that the counter is wide enough for preparation and such---I added a wider and somewhat longer counter for a customer who was frustrated to tears with the lack of space for ingredients and tools around the cook top---
Although I have worked on almost ever part of her house--she thanks me for that top almost ever time I see her.
Little things mean a lot---your kitchen is a work shop----lousy layout takes the joy out of working in it---so take your time---make a mock up using sheet styrofoam if you can't picture how the layout will work-----this extra effort will pay you back for the life of the kitchen---Mike----
mae-ling (10-07-2012)
Old 10-07-2012, 11:31 AM   #5
Stove in peninsula?
THey have hanging hoods that shouldn't block you view, would be above your view.
many styles and prices. http://www.google.ca/imgres?hl=en&sa...w=1112&bih=748
If budget is a concern I have heard of a guy who used Oak plywood (whatever type you want) to cover in regular ducting to the ceiling. then the guts of a regular hood or a liner you can buy.
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
