Sterling Shower Base - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-02-2014, 03:22 PM   #1
Sterling shower base
I just purchased a Sterling shower base that is made for the surround shower walls. My question is can I use it as a shower pan and then tile around the shower pan and up for the walls?
dennis blocker is offline   Reply With Quote
Old 07-02-2014, 08:01 PM   #2
DIY staff
Rewards Points: 7,174
Post a link to the model---most can be used with tile--but not all--
Old 07-02-2014, 09:21 PM   #3
I am sorry I can not post a link.
Old 07-02-2014, 09:29 PM   #4
shower base from Kohler
I called the Kohler company and the lady I spoke with said that that model was ok to be using it as a shower pan and to tile up the walls instead of having the complete ensemble. If you do a google search you may be able to see the product under the tab bath and showers.
Old 07-02-2014, 09:33 PM   #5
It is 7212 Series . It is under Ensemble. I hope that helps
Old 07-02-2014, 09:35 PM   #6
The size is 48 x 36
Old 07-02-2014, 09:37 PM   #7
Correction , it is a 48x34
Old 07-03-2014, 05:56 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Yep, says right on the receptor page its okay to use with tile installation.
12penny is offline   Reply With Quote
Fix For ELM Shower Base Drain Leaks MarkSilber Plumbing 0 02-14-2012 09:02 AM
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
How to build base for a shower stall atm Plumbing 13 05-13-2009 10:18 AM
