Starting My First Tub-to-shower Conversion! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 01-08-2016, 12:06 AM   #1
Rewards Points: 78
Starting my first tub-to-shower conversion!
We've lived in our house for 16 years. In that time we've used the giant garden bathtub in our master bath maybe 5 times. I'm sick of looking at it take up a 1/3rd of our space in there. After years of wishing we could afford someone else to do it, we've finally decided to do it ourselves!
will post picts next....
chakotay is offline   Reply With Quote
Old 01-08-2016, 12:17 AM   #2
Rewards Points: 78
the picts of where we're at. Took a hammer, crowbar, and reciprocal saw to it...
Starting my first tub-to-shower conversion!-img_20160104_195019.jpg   Starting my first tub-to-shower conversion!-img_20160105_212335.jpg
Old 01-08-2016, 07:59 AM   #3
DIY staff
Rewards Points: 7,174
Great project----keep us informed---what are you planning to do with that window?
Old 01-08-2016, 08:20 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You may not want to hear this but, a shower requires a 2" drain vs the 1.5" that most tubs have.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
ddawg16 (01-13-2016)
Old 01-08-2016, 08:31 AM   #5
Rewards Points: 78
The window stays. Since it was never able to open anyway, we were thinking about glass block. Rjniles, the drain pipes are already 2" (inside diameter, correct?) This is a relatively new house--built 2000--if that makes a difference.
Old 01-08-2016, 08:34 AM   #6
A "Handy Husband"
rjniles's Avatar
You are really lucky on that. You dodged a bullet that hits may others.
oh'mike (01-09-2016)
Old 01-13-2016, 10:27 AM   #7
Rewards Points: 78
Hit my first snag . . . but that won't stop me! Looks like the jokers who framed the house (or laid the plumbing) missed their mark. The water pipes are not entirely INSIDE the wall, but a little less than an inch OUTSIDE. As of now, they're extending into where my pan will be. See pict. What are my options? I'm thinking carefully break up the concrete and shove them back into the wall? What would the best tool for this be, given that there's copper pipes embedded in there?
Old 01-13-2016, 10:52 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
If that is the worse thing you find....you will be in great shape.
On that window? Personally, I'd replace it with a new vinyl double pane. Fresh air will do wonders for keeping mold down. If you do replace it, make sure it's tempered glass.
ddawg16 is online now   Reply With Quote
Old 01-13-2016, 11:15 AM   #9
Rewards Points: 144
A rotary hemmer with a small chisel would be your best bet .Chisel along the sides of the copper.Not towards it.Whoever sweated that copper was no plumber .
mako1 is offline   Reply With Quote
Old 01-13-2016, 11:44 AM   #10
Rewards Points: 78
Yeah. I'm sure whoever sweated the pipes was whoever the contractor picked up outside 7-11 that morning!
ddawg16, Yes! We desperately want to keep the window, but add some venting. We live in Texas and in the summer it can get stifling in the bathroom after a shower. We like this idea in the picture below.
I read somewhere on this forum about the bottom height of the window needing to be at least 60" from the floor of the shower. Not sure if that's code in my area, but would using glass block negate this requirement?
Old 01-13-2016, 11:52 AM   #11
JOATMON
ddawg16's Avatar
Not sure about code....may not apply to existing...but I do like to look of that setup.
Old 01-28-2016, 11:32 PM   #12
Rewards Points: 78
Bought a cheap rotary hammer from Harbor Freight and got the pipes free of the concrete!
Next question: I want to move the drain to the center. Can I just cut a channel in the concrete, put an elbow joint on the existing drain pipe and run it there (with a slope of course).
Or does the P-trap have to be moved to directly under the new drain location? Currently, the P-trap is about a 1-1/2 feet down next to the wall. Looks like the vent is a couple of feet from it. (see picts)
Iíve read something about only being able to run pipe so far from a vent.
Old 01-29-2016, 01:43 AM   #13
JOATMON
ddawg16's Avatar
The p-trap should be under the drain
If it was me, I'd just enlarge the existing hole.
I've learned that it's easier to patch a big hole and have plenty of room to work with than patch smaller holes and kill yourself trying to work in that small space.
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (01-29-2016)
Old 01-29-2016, 08:18 AM   #14
WhatRnsdownhill's Avatar
Rewards Points: 2,220
just cut out that old trap and extend 2 inch so outlet of trap is inline with shower drain, makes cleaning trap or possible clogs easier....what kind of shower pan are you going to use?
WhatRnsdownhill is offline   Reply With Quote
Old 01-29-2016, 10:10 AM   #15
Rewards Points: 78
I'm building my own shower pan! Never done it before, but I have watched lots of videos and it seems like something I can manage. I HAVE done tile work before, but this will be a first for me in a shower.
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 08:23 AM
Shower Leak Herk_Man Plumbing 10 04-14-2013 05:19 PM
Shower Rough In - Miscellaneous Questions tev9999 Plumbing 1 02-13-2012 10:40 PM
tub to shower conversion for wheelchair lmatl Plumbing 5 09-01-2010 09:06 AM
shock in shower tbwoods Electrical 64 07-23-2009 12:26 PM
