Split Vanity - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 02:53 PM   #1
Rewards Points: 27
Question
Split vanity
Hello, I have a 72" dual sink master bath vanity that is about 28 years old and I'd like to replace it. It's at the kiddie height, whatever that is (I'm at work)
To save money, I'm considering buying two 30" cabinets and leaving 12" in between for a trash bin. Then getting a one-piece top to lay across both and connect them. My slight concern is the plumbing because of the height differential (and possibly the horizontal offset depending on the position of the sinks on the new counter top).
Your thoughts? Anything I should be concerned with or look out for? Better, anyone ever do this?
AngeloUCF is offline   Reply With Quote
Old 04-14-2010, 07:29 PM   #2
remodeling pro
I think the 12" space will always look like the result of a cabinet mistake, I would butt two 36" units, and find another spot for the trash can. The plumbing should be no problem, it should just require longer tailpieces on the vanity drains, and the horizontal offsets are no problem either, unless the units have drawer banks to consider.
troubleseeker is offline   Reply With Quote
Old 04-14-2010, 07:31 PM   #3
see if you can get a 12" tilt out or slide trash bin with matching cabinet face as your spacer
The older I get the better I was
Old 04-16-2010, 10:19 AM   #4
remodeling pro
That negates his theory of saving money with the 30" cabs vs the 36" cabs, because the 12" cabinet will cost more than the price difference of the other two. I have never seen a manufactuer offer a 12" trash unit, it is too small to be functional. If he has to have the trash can at the vanity area, I would still go with the 36" cabs and see if the plumber can work the pipes to assure enough room to add an aftermarket trash can pull out in one of the bases.
Old 04-16-2010, 10:32 AM   #5
Rewards Points: 27
Thanks guys, I may end up going with the one piece 72, it's just amazing the price difference is ridiculous considering I can get 2 36" for around 4-500.
HELP! Vanity tight squeeze 9728 Kitchen & Bath Remodeling 1 12-11-2009 02:53 PM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 02:30 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
