Soft Close Door Gadgets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-28-2013, 09:43 AM   #1
Rewards Points: 236
soft close door gadgets
i am looking at these for my new cabinets. i bought some plastic ones from manards, they don't work well. any other recommendations ?
Fix'n it is offline   Reply With Quote
Old 11-28-2013, 09:52 AM   #2
Rewards Points: 14,020
Might want to let us see what type hinges and cabinets you have now, and what you bought that did not work.
Old 11-28-2013, 09:56 AM   #3
Davejss's Avatar
Rewards Points: 776
There are a bunch of manusacturers that make a European type cabinet hinge with the soft-close feature. So, if you have standard 35 mm euro hinges you should be able to do a relatively easy switch.
A quick check at Hime Cheapo's site showed some at around $10 a piece. I'm sure you could do better on-line.
Davejss is offline   Reply With Quote
Old 11-28-2013, 10:24 AM   #4
Rewards Points: 236
here ya go. the ones that were on these cabs at the building supply where we bought them worked very well. but doesn't mean they are good.
http://www.amazon.com/Blumotion-Hing...sim_sbs_misc_5
and i sure don't want to spend $10 each.
Old 11-28-2013, 10:31 AM   #5
Rewards Points: 236
here are the gadgets. they are not strong enough. the door can hit a little hard and often bounce. though they are better than nothing, imo.
Old 11-28-2013, 10:46 AM   #6
Rewards Points: 42
Originally Posted by Fix'n it
here ya go. the ones that were on these cabs at the building supply where we bought them worked very well. but doesn't mean they are good. http://www.amazon.com/Blumotion-Hing...sim_sbs_misc_5 and i sure don't want to spend $10 each.
The Bluemotion closers are good. I have a different style that clips onto the hinge. You'll find them cheaper from an online cabinet hardware store.
Y
Dan
djlandkpl is online now   Reply With Quote
Old 12-01-2013, 11:52 PM   #7
MT Stringer's Avatar
Rewards Points: 254
Check out Custom Service Hardware. Blumotion soft close hinges work great. And you can adjust them to close softly, not so softly, or no buffer at all.
Much cheaper than $10 each.
MT Stringer is offline   Reply With Quote
How to get double front doors to close tight Advising Elf Windows and Doors 31 12-30-2012 11:09 AM
Fixing kitchen cabinets where the hinge won't completely close the door zappero Kitchen & Bath Remodeling 3 04-28-2012 10:20 PM
How close to a fence should I plan 7 gallon arecas? Drywallhelp Landscaping & Lawn Care 8 01-10-2012 09:32 PM
Remove and close off old stove hood venting Chickylala Kitchen & Bath Remodeling 1 09-09-2011 01:02 PM
french doors dont close "easily" redroc25 Building & Construction 6 05-12-2011 01:18 PM
