Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling > Kitchen & Bath Remodeling
Old 11-04-2009, 03:35 AM   #1
Default So many questions - tub installation, floor tiles, subfloor...
Hi there,
Just starting a complete reno of our ensuite and I'm learning as I go...
Tub/Floor Tiles
I have to replace the tub (old one was cracked along the edge) and am replacing the floor as well. We are planning on a tub with an apron rather than a drop-in as we didn't like the look of our old drop-in tub. When I visualize where the tub apron meets the tiles, it seem like it would be a nicer edge to tile first (to cover a little under the tub edge) and then mount the tub over the tiles. Is this OK to do or should the tub always be mounted first and then the floor tiled up to the edge of the tub?
Old Subfloor Removal
The old subfloor is quite a mess after the old tiles were pulled up. What is the best way to remove the old subfloor while getting as close to the walls as possible. I've seen recommendations to use a circular saw with depth set to the subfloor thickness but that would seem to me to leave quite a large strip of the old subloor around the wall edges. Do people just normally leave that old strip around the edges or is there some other technique to get the old subfloor out with less clearance to the walls required?
I'm sure there will be many more questions to come I'm sure but any answers/suggestions on the above questions would be very much appreciated.
Thx,
Chris P.
chrispy35 is offline   Reply With Quote
Old 11-04-2009, 09:27 AM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
I've installed the tub 1st then tiled at both houses so far
With tile under the tub it would be a pain to removed & redo the tile
I just left the old sub-floor near the walls
Adding a 2x for support may be needed depending upon joists
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-04-2009, 12:39 PM   #3
RDS
I agree with Dave about the tub-tile joint. I don't think I'd be comfortable with the tub apron (esp if cast iron), plus the weight of water, plus person bearing down on the edge of a row of tile. In theory it shouldn't crack if the structure under it is sound, but I'd worry.
For cutting the subfloor flush to the bottom plates of the walls, don't they sell small wood-cutting blades for angle grinders? I may be wrong about this. I know they sell them for cutting masonry, tile, etc. The one time I dealt with this problem I just used a flush-cut saw (hand tool) flat against the side of the bottom plate, but that was tedious and, in retrospect, probably not necessary.
RDS is offline   Reply With Quote
Old 11-04-2009, 05:17 PM   #4
Thanks guys, the issue of the weight on the tiles and possibly cracking also occurred to me so I appreciate very much the extra opinions on the matter. Tub first it is.
Dave, when you say 'adding a 2x support,' do you mean a 2 second layer of plywood over the subfloor? I've seen this mentioned before and it's probably a good idea in this case as the old tiles cracked along a seam in existing subfloor. What I wonder though is how people deal with the extra thickness of the floor at the transition to the bedroom? Is there a good-looking way to handle that difference?
Thx,
Chris P.
Old 11-11-2009, 01:18 AM   #5
Another reason to place the tub in first, so that it can be leveled. This is important if you are going to be tiling the walls. More often than not your floor will not be level. If your tub is not level the more difficult it is to tile the walls. If the tub needs to be shimmed up in front, installing the floor tiles after should cover the line of sight along the apron.
Work is for those who can not fish.
Mop in Hand is offline   Reply With Quote
More On This Topic
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
I’m Lee. I have a degree in architecture and about ten years in the construction field and today we’re doing a fairly ornate countertop in my own house. Both of the countertops are using the basic same colors, but it’s a different tile... Read More »
Bathtubs can be dangerous places for those with disabilities. It's important to lay out the bathtub area carefully to provide optimum safety. Depending on your budget and space, there are a variety of modifications that can be made to help insure a safer... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment I am going to be showing you how to do a dry run with your tile to make sure the layout is working. As you can see we have snapped our lines and what you can do if... Read More »
Ceilings in an older house can be unsightly. A relatively inexpensive way to solve the problem is to install ceiling tile. While you can attach ceiling tile directly to the ceiling with glue, it's easier to install furring strips and attach the ceiling... Read More »
[IMG] code is Off
Subfloor and Underlayment Questions JulieZ Tiling, ceramics, marble 14 06-23-2009 10:04 AM
Kitchen subfloor questions tishimself Tiling, ceramics, marble 7 12-09-2008 11:16 AM
Floating floor installation over tongue and groove subfloor help Delairen Flooring 0 11-05-2008 03:21 PM
Questions before laminate installation. darsunt Flooring 2 11-27-2007 03:00 PM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 10:37 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
