Small Crack (2.5in) In Mirror By Light Fixture - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 06:08 PM   #1
Small crack (2.5in) in mirror by light fixture
While installing the second of two floating light fixtures on a new bathroom mirror a small crack suddenly appeared. I thought i was being very careful and just barely finger tightening it as i had on the first one. It 's only 2 inches long but noticeable. Is there any way to fix it or am i looking at replacing.
dmannne is offline   Reply With Quote
Old 03-17-2013, 10:13 PM   #2
Rewards Points: 14,306
There is no fixing it and there's a real danger it may just shatter. Get it out before someone get cut.
Old 03-23-2013, 09:50 PM   #3
If it runs to the end of the mirror, it has run. If the crack ends inside the mirror, it will run at some point. Pressure, vibration, and heat are a few things that can make it run. So basically the mirror will break at some point. If you're gonna remove the mirror, run the crack first. Or have a pro do it. When installing a light fixture on a mirror, you should shim the fixture out. It's best not to have it resting on the mirror.
sgjordan is offline   Reply With Quote
Glass light fixture has hairline crack inside. Pmaniya Electrical 2 11-08-2012 01:03 PM
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 09:06 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
Light fixture issue baustin Electrical 4 07-17-2007 04:01 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
